716 Governor Set Up.
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: 716 Governor Set Up.
    Posted: 01 May 2017 at 7:04am
Would anyone have a picture of how the governor/throttle linkage is set up on the 16HP Kohler in the 716? To make a long story short, I have switched engines and need to know how the linkage is set up and what holes the springs should go in. When I open up the throttle now, the engine wants to run wild. I haven't had a chance to adjust the governor arm on the shaft yet. Maybe that is my issue. Thanks!!
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 5:12am
The arm on the shaft is your adjustment. Get that set and you should be fine.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 6:52am
Thanks Dgrader. I worked at it last night and did that. Works great now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 5:45pm
Good deal.
