C Pedestal Stud, etc. |
Post Reply ![]() |
Runamuck ![]() Bronze Level ![]() Joined: 22 Oct 2014 Location: West Central Mn Points: 31 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Apr 2017 at 12:07pm |
Been working on my '41 C alternator and removed the fan pulley to free up adjustment to get belt to fit. One of the studs that hold the front pedestal to the engine block has been broken off since before I owned it. Does anyone know where I can find a stud and the part number? Also may as well replace valve cover and oil pan gaskets that are leaking, and radiator hoses. Is there one place that has all this? Haven't been able to find anything on the stud. Also need governor spring for '48 C.
Thanks, Bill. |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
You can use a 1/2" grade 5 or 8 bolt. The studs are 1/2" curse thread into the block with 1/2" fine thread on the outside.
Thanks, Dick. That should work, I guess. Didn't even think about that!
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1278 |
Rear axle stud from a truck works too. |
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2033 |
Got it all including the special nut on the stud.
Post Reply ![]() |
