Installing Alternator on WD Allis
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Installing Alternator on WD Allis
    Posted: 13 Jun 2010 at 5:23am
I have installed a GM internal regulator alternator on this tractor.  I have acquired the snap in/pigtail harness (diode built in) so that the one wire coming out of this pigtail goes right to the post on the back side of the alternator.
The other wire off of this pigtail harness...do I connect it to the tractor generator harness wire that has the large ring terminal?  What do I do with the other wire from this tractor generator harness?
Thanks in advance for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 6:35am
Will this help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 6:38am
You can replace the coil with a 12v coil and forget the ballast resistor.
Edited by CTuckerNWIL - 13 Jun 2010 at 6:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 2:54pm
Thanks for the help.  It is now working.  However, it is sending current up to 30 amps (as read on the amp gauge) when even at a mid-range engine speed.  Is this expected?  I didn't run it too long like this but did confirm the wire on the "batt" post of the alternator was starting to get warm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 3:04pm
I would charge the battery with a charger and make sure it is up all the way. Then run the tractor for 10 minutes and see if the rate of charge drops off. If it doesn't, I think you have a problem with your internal regulator.
Edited by CTuckerNWIL - 13 Jun 2010 at 3:04pm
This page was generated in 0.049 seconds.
