706 Forklift?
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: 706 Forklift?
    Posted: 29 Apr 2017 at 3:51pm
Going to go look at a 706 forklift tomorrow. I don't know anything about these. Seller says this one has a 4 cylinder Perkins and a torque converter. What can you tell me about them??
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 6:04pm
They're a good forklift. Check torque converter fluid level & color. Check to see if Trans pops out of 2nd gear (most popular gear (worn shift forks & shift collar gear). Perkins isn't going like cold weather starts, so look for collateral heater. Side shift forks are a great feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 6:05pm
Not collateral heater - coolant heater. I hate spellcheck
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 7:59pm
The 706 is not based on any A-C tractor so second gear should not be  problem. Similar power train to the 715/715B TLB and I've had one of those for 40 years. Power train is bullet proof. My literature lists a 203 Perkins, Borg and Beck torque converter, and I know the drive axle is Ford. Should be a mid 70's vintage.
Edited by Calvin Schmidt - 29 Apr 2017 at 8:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 7:55am
I own & have operated two of these for over 15 years. I bought both in used condition. One is a gas 706B, other is a 706D. The 706D has always popped out of 2nd gear. Previous owner wore out 2nd gear, and was decent enough to communicate it before I bought it. It is still a good machine. I never mentioned it having an AC Trans. I also own a 715. I've had to repair torque converters on two of them. So, Trans are good, but I don't believe they are bullet proof.
This page was generated in 1.229 seconds.
