slow rim leak on WD
Dennis IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Topic: slow rim leak on WD
    Posted: 12 Jun 2010 at 9:48pm
I have a very slow rim leak on the Wd right around the valve stem (there was cc in there but I drained it out because that's what was rusting it out) the rest of the rim is excellent. What I'm wondering is if you guys think a little JB weld might do the trick?  Dennis.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 8:53am
It's your tube that is leaking - not the rim.  However, a rough patch inside the rim could be causing the tube to leak.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 8:55am
exactly...if you dont mind the look of the rust outside...pop the tire off and clean the rough area inside, and re-tube it....its the only real fix.
This page was generated in 0.048 seconds.
