control upgrade
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: control upgrade
    Posted: 27 Apr 2017 at 1:24pm
I had converted the old Allis to a single control but never liked the amount of stroke and the overall efficiency of the mechanism.  I came up with this, will see how well [IF] it functions.
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 2:02pm
seems like the 7g we had the the 2 sticks just like the 6g did im might be wrong now I know for sure the 7gb had one stick.    that's a nice looking job dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 3:24pm
G-B did have single, but the hydraulics layout was also different with the control valves on the side not top of tank.  This brings a lot of hand movement down to minimal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 3:54pm
I bet it helps . on that 6g when you go to raise and lower the boom if you forget to push it back in the middle going down it will keep going and pick the machine up lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 5:26pm
My machine has the return to dig detents, when you pull full back it latches in and the linkage alongside the lift mechanism trips the bucket then drives the bucket back down.  If you do not catch it the loader will try to raise the tractor.  Is suspect that was in allowance of the multiple levers and redirection of the machine requiring BOTH hands, one for clutches one for shifter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 7:00am
With the reman'd bucket on the control is a lot crisper and shorter throw than what I had made prior.  Still a learning process on use or getting used to it.
