Fehr cab interiors co. for door seal
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Topic: Fehr cab interiors co. for door seal
    Posted: 22 Apr 2017 at 2:32pm
    Does anyone have any experience with Fear Cab Interiors Co.? I need to replace the door seal/ weatherstripping on the left hand door of our 8070. Agco sells a roll of weather strip and tube of glue. This kit seams to be mitered to length. If so this would be a ton nicer to install.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 2:51pm
I installed one on my 8070, fit perfectly. Start at a top corner and work your way around. Fehr has self adhesive strip so just peel off the paper as you go around. Well worth the money and is just as close to oem as you can get. Just make sure old adhesive is cleanded off good. Mines has been on for 2 years and is still sticking excellent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 2:57pm
     Thanks for the reply. I stripped the tractor down to bare metal and primed and painted it. The original seals were all good so I glued them back except the left hand was tore up.
