XT 190 pyo brake
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: XT 190 pyo brake
    Posted: 15 Apr 2017 at 6:40pm
Have a persistant hydraulic leak  at a tee fitting down by a drain plug for i think is tranny. The  T has male thread going into a round housing held in with s snap ring, a short hose from another round housing rainbows up over a center round housing into 1 side of female part of T, the other female side has a steel line going back to valve stack, as well as a steel line from middle round housing I am 95% sure this related to pto brake valve if I read part diagram correctly. I am needing  the T - #70914762 in Agco parts book but hoping someone can verify my part. Tried getting the T at our local hydraulic repair shop but no dice. Tractor does have hydraulic pto engagement. Thanks.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:12pm
That is the correct part number for that tee.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:15pm
THANKS. There are GOBS of pages for hydro system,not to mention the serial # breaks.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:28pm
I was surprised the AGCO parts book has a hose between the Brake pistons. My 190XT has a steel tube, The tee has an 1/4 npt thread on the side and 3/8 inverted flare connections on the run. I looked at another housing I had, but the tee was broken off and the tube/hose was missing.
I would double check to see what was actually used on your tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:44pm
Joe, the hose is what is on our tractor, I just removed the TEE this afternoon and discovered the male stem was almost broke in 2 and I accidently finished it off. You guys seem to be "IN THE KNOW" about parts,could either of you tell me if this part is still available anywhere in the USA ?
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:59pm
I have a new old stock here I will send you a PM
Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 9:08pm
An Agco dealer should be able to give you price and availability. Plus they should be able to check other dealers inventory to see if anyone has it in stock. (Not likely). And welcome to the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 9:13pm
Lynn, thanks for the welcome but i have been a member for several years but some how had a snafu last week when editing my profile. Had to do like Shameless.
This page was generated in 0.110 seconds.
