B212 rear light not working
NATHAN CAIRNS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Topic: B212 rear light not working
    Posted: 14 Apr 2017 at 2:02pm
The rear light on my b212 isnt working. I checked the voltage and there is none. What could have went wrong
B212, WD45, B, 912 Hydro
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 2:57pm
broken wire
GlenPettit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenPettit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 7:23pm
Also check your contacts, where the wire connections are attached.  It's common for those flat surfaces to oxidize, like 'rust', and build up a thick non-conducting surface, kinda like a washer, preventing the electricity to get through . . . a very simple fix; just sand those contacting surfaces and coat them with Vasoline or a conducting gel.  This is probably a more common cause than a broken wire on our tractors.
Good Luck
Glen
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 4:41pm
ok thanks    i took a dremnel and sanded the posts but it still dont work    ill pop the sheet metal off and take a look at the wire and other posts tomorrow
