226 engine gasket set for gleaner e M coded
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Topic: 226 engine gasket set for gleaner e M coded
    Posted: 13 Apr 2017 at 1:26am
We got an engine out of a gleaner E that is a 226 M coded engine. It has a blown head gasket. Will any of the aftermarket gasket kits for the G226 engine fit this M coded engine? It's going in a WC that has a stuck engine at the moment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 6:27am
Should work.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 9:43am
WOW!!!  A WC with that much horse power!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 11:26am
We are using the governor and mag off the WC. No need for that much power. It might just walk right out of its tires as it is. They are pretty dry rotted.
