545
Mickey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mickey Quote  Post ReplyReply Direct Link To This Post Topic: 545
    Posted: 12 Apr 2017 at 7:12pm
Bought 545 recently with 2900 engine so any advice/info is appreciated since i dont have operators manual. What i am most interested in atm is oil type and quantity for transmission
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 7:58pm
Allison Transmission
2 speed forward
and 1 speed back
its ATF3,
-If its a little red colored then its ATF3,
some people used 10 w oil i would not mix
the two
do you have a dip stick or not ?
dose it look like this?
http://files.minnpar.com/partbooks/WHEEL%20LOADER%20MANUALS/FIAT%2DALLIS%20WHEEL%20LOADER%20MANUALS/545%2C545H%20PM%20%2373063928.PDF
          B:-)      Dnoym
Edited by Dnoym N. S. Can. - 13 Apr 2017 at 9:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 10:34pm
Wow welcome to the forum. Goodluck
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 1:47pm
The best success I had with my 745 transmission (just a bigger Allison) was using 30W engine oil giving better pressures as well as improved metal to metal protection. If you're not working the machine hard the thinner oils will do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mickey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 2:45am
Hey Dnoym, thanks for the info. I didnt notice dipstick anywhere. Thanks for the link, i already found and dl-ed it, but couldnt find operators manual for free.And yes, it looks like on pic 2, since cab is not mounted yet. I will post some pics soon. Currently i m working on engine so when i m done, i guess i'll have some more questions :-)
Thanks MikeZ
Thanks to you too Eric for that info
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:31pm
The dip stick is missing
my 1967 545d loader
dose not have a dip stick
it has two check plug about
one in. apart haft way up the tran
on the engine side
the bottom one is the low level
and the top one is the full level
check running after warming up
 and in neutral
l . mine also has
a tran filter by the engine on
the cooler line
i have a 1967  545D with a 301
and 2 speed power shift
 i have a 545D operator
manual and in the manual it
say
lubricate these with SAE 10w oil
meeting ATF type c-1
so i think that SAE 10W oil or
ATF type C-1 is what they went
with in 1967 so i don`t think
it need anything special
i don`t know if tractor hydraulic
would work (i can`t see why not) but
the only thing that i did with mine
was to take out about 5 gal of
oil because they could not find
the dip stick
to check oil set park brake
take the top plug out with drain pan
if no oil add oil replace plug
and start engine and run at 1000 to
1500 rpm for 1 min. to charge system
then take out the bottom plug  and
add oil as required stop engine
this is what mine look like
uploads/1493/GetAttachment7.jpg
do you have a manual HTH
if you need more info let me know
let us know how you make out
B:-)    Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mickey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 6:01am
ok, i missunderstud dipstick question last time since i m not native english speaker,
so there is a dipstick, the model is TT 2220-1
i m not sure what is the difference between 545H and 545D?
i made some pics, but lets see if i understand the posting tutorial well:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mickey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 6:31am
ok, it works Smile
working in progress Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 10:45pm
for what it's worth...I was searching net on Allisons and found a place in Texas that was rebuilder.Their info said use 15W40 oil.seems that one of the Ausies chimed in and said that's what they were using.My 78 545B has dexron in it...and it's transferring trans to hyd.Both are using dexron.
AC_Digger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC_Digger Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 5:24am
re. 545 H
Been the happy owner sins 2002 and it has Dexron in transmission and 10/40 to the engine "it improve the turbo sound :)  "
I drain it ones and it took about 28 litters ATF oil.
A redline a day keeps the carbon away !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mickey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2017 at 10:27am
After assembling engine (it worked perfectly Smile ) i went to try it out but felt some lack of power. Drained tranny oil and found metal pieces. Took it off, dismantled and found broken parts of the clutch kit Confused
So, i am looking for items 8, 9 & 10 as shown on the picture from parts catalog, new or used. Thanks in advance for any help and info
Transmission plate info:
Allison division
Indianapolis indiana
Ser 28117
Part no 6835015
Tt 2220-1
Gadget View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gadget Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2022 at 4:12pm
Would anyone have any 545 loader manuals they could share?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2022 at 6:49am
If you don't get other responses, eBay appears to have many choices, parts, service and operator's manuals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC_Digger Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2022 at 2:12pm
workshop or user manual ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gadget Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2022 at 9:13am
I'm interested in any information I can get. Knowledge is power. But if i had to choose a shop type manual would be first.
