70 series 4 bottom plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 70 series 4 bottom plow
    Posted: 11 Apr 2017 at 8:29pm
I recently purchased a pretty good 70 series semi mount 4 bottom plow. I used it this week and I may need to make adjustments. I dont have a book and haven't seen one yet. Every one I see shows snap coupler not the newer 3 point lift arm attachment. Anyway, I can get the front bottoms down to the colter axle but the rear isn't riding on the depth wheel. It's set for about 10 inches if I am correct by measuring while the plow is setting on level ground, the tire is 10 inches off the ground. I put the hydrolic in float(rear tiller wheel lift). Rear plow is only going about 6 inches deep at most. What am I doing wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 8:32pm
Might have a manual. Will check tomorrow
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 8:58pm
Thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 9:03pm
Will try to post the short video of my brothers newly restored 190XT pulling it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 9:12pm
Tilt plow to the left. Is tail wheel stop going against bolt? May need new shears.    MACK
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:36pm
With the three point hitch, the lift arms on the tractor set the plow left/right tilt and you want it level with the right side tractors tires in the previous furrow. One way of setting is to put the left wheels on blocks the depth you plan to plow while on level ground and level the plow. The top link usually sets the fore to aft tilt so to get the rear bottom to plow the same as the front bottom the top link needs to be lengthened. Some plows have an adjustable link from the hitch to the back of the plow frame for that adjustment.
Gerald J.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 11:35pm
 I agree with Mack.
Thanks & God Bless
Dennis
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 8:10am
Gerald, a semi mount plow wouldn't have a top link.
I agree with both Mack on leveling, and about the shears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 10:17am
True the semi mount won't have a top link. I just looked through the plow frames parts book and I found several versions of the semi mount hitch but nothing like a top link to adjust the depth of the rear of the plow. Could very well be the bottoms need deep suck blades (shears) to pull the bottoms down. With my 4x18 modified to 3x18 2000 monoframe plow I never had any problem getting the bottoms pulling down to the rear gauge wheel.
It could be that the hitch needs to be lowered to give it less tendency to lift the rear of the plow frame.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 10:36am
Gerald J.
On a semi-mounted plow the frame is freely floating. The only way to lift it up is the hydraulic lift on the tail wheel. The only way to keep it from digging to deep is the depth gauge wheel. So if the plow is not cutting in to the depth that the gauge wheel is set then the shares are worn and need to be replaced.  May or may not need the "deep Suck" shares. This depends on the ground.
 Just remember that the plow was design to cut at a depth of half the width of the moldboard. So a 14" bottom will be 7" deep, 16" is 8" deep and 18" is 9" deep.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 9:16pm
Good info, the strange thing is it has a top link attaching point on the plow. I didn't use it because it didn't make sense to. I figured the same frame could have been the same for a lift plow. Good points about the shears. Can I still obtain parts for it and if so who is a good supplier?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 9:29pm
The plow frames are the same for the different hitches. Only the hitches change.
If it has a top link its a three point hitch, not a semi mount and attaching the top link and lengthening it should put the rear bottom into the ground. Alternatively a weight will do that using the trailing lift wheel and the gauge wheel to set the depth.
There are vendors on this forum with plow shears but first you have to identify the plow bottoms. There is an extensive article AC Plows Parts 101 over on the Knowledge Forum that gets into details and links some downloadable plow frame and plow bottoms parts books. You need to find a part number on the moldboard or share or maybe the frog and then in the plow bottoms book you can identify the bottom. And can identify what the part numbers were for shares and other wear parts. Coulters and landsides were practically universal. And AC offered dozens of plow bottoms in 12 to 18" in the 70 family era that fit every plow frame they made. A couple of the latest bottoms still have parts made by aftermarket plow parts makers.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 9:34pm
Can you post a picture of your plow?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 8:46am
I don't intend to argue with Gerald....he may be right. But it surely seems to me, that if you have a 3 point mounted plow, and not a semi mount, your top link would hold the plow up, not "shove" it down. Yes, the longer the link, the more the back of the plow could go in the ground, but with no link at all, the only thing holding it up would be the trailing wheel, since a plow should be wanting to dig in. This is confusing to me. I've never had an Allis mounted plow, but the mounted plows I've had, the trailing wheel was fixed since the 3 pt hitch lifted the whole plow. The gauge wheel is there as just that, a gauge, you don't necessarily have to have it rolling on the ground, just skimming the ground, or even on the frame. The gauge wheel doesn't set or control the depth, it shows you when you get there. IMO. If you have an attachment point for a top link, AND it IS a semi mount plow, then the plow hitch must pivot on it's own? I'm not Allis plow expert, but I do own a deere plow made like that, but much much newer than any Allis plow, it's called a "double pivot hitch". So back to the trailing wheel, it has to be what's holding you up...Is the cylinder travel allowing full adjustment? Is there a stop screw holding you up? You say, "front is down to the coulter axle, but the rear isn't riding on the gauge wheel". How deep is the last bottom plowing? Check the height of the dead furrow wall....and let us know! Bad shears can make it skid across the ground, but if it's like 5 inches deep or something and you want it deeper, there's some other adjustment you need to make..
Edited by Tbone95 - 13 Apr 2017 at 8:46am
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 9:15am
The longer the link, the more the tips will point upward, causing the plow to rise and to plow shallower. As the plow rises, the tips even out until a neutral position is reached. Ditto with a shorter top link. It causes the plow to sink deeper before this neutral point is reached. I've never seen a 3pt fully-mounted with a seperete depth adjustment. The crank on an AC plow works in a similar way. It adjusts the forward/backward tilt, changing the depth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 9:43am
That makes some sense too DougS. I guess it depends on how short "short" is and how long "long" is. I could see it both ways. It seems that could change the "suck", not so much the depth, as lowering the 2 arms still puts the front bottom at a depth relative to the tractor, and if you had it "way too short", you could be pulling the tail out of the ground so to speak. Still, if this is a semi mount, the only thing holding it up at the rear of the plow only has to be something in the tail wheel?
Edited by Tbone95 - 13 Apr 2017 at 9:46am
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 10:55am
Do you have a transport valve if you don't the rear of the plow won't stay in the ground.
turbocharged
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 11:05am
Maybe try lowering the tail wheel, then putting the hydraulics in neutral rather than float?
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 9:18pm
    DougS said it right.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:13pm
I'm trying to post some pictures shortly. I have watched videos with tractors using these plows and dont see any using a top link. Not sure why the top link attaching point is there. It appears factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:23pm
The front plow depth is controlled by the lift arms, rear of plow by the hydraulic cylinder at the trailing wheel. The trailing wheel goes down to the stop. The shares could definitely be in need of replacement as the tips are rounded instead of a point. No change if it is in neutral instead of float as far as changing rear depth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:26pm
If Matt doesn't have manual I have one. Operating instructions 70 and 80 series 4 and 5 bottom plow (semi mounted) form TM-291A. Have one for a no.74 4-bottom also form TM-160.
The shares will make it act all sorts of weird. Start there. Have any part numbers
Edited by Mikez - 15 Apr 2017 at 8:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 9:08pm
No decals other than the small AC ones on the back of the plows. Where should I look for serial numbers or any other identification info? And would like to have at least a copy of a manual. PM me if you would like to sell a manual or if I can pay for a copy. Ty!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 9:30pm
Look on the back of the moldboards for any numbers stamped into it. If no luck un bolt a share to see if any stamped on back of them, if not unbolt shine and look. There should be part numbers stamped on backs of parts, then we can look in plow bottoms parts book and see what no. bottom you have. Yes I will sell you a manual but lets see what you find to make sure have the right modal plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 5:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 6:07pm
Finally got some pictures on the forum! Hope this helps in identifing my plow. The hydraulic hose burst so until I get a new one, I can't fully raise the plow to pull a share to look for numbers. Until then I would just to like to verify that this is what I believe is a series 70 semi mount. Once that has been established I can get a operators manual. Some good ideas from all of you.
This page was generated in 0.176 seconds.
