AC 170-175 plow size
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170-175 plow size
    Posted: 10 Apr 2017 at 8:08pm
Would a 170-175 pull a 3 -18 semi-mount AC plow well? Does it have plenty of horsepower in clay type soil? Tracy
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:14pm
I've seen them a pulling 3X16 right along. Weighted right scoured good, I would think she do her. Heavy clay might be a little slow.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:31pm
I pulled 3x18 (AC 2000) plow in various soils with my '68 gas JD 4020 at about 5.5 mph. It pulled 4x18 but I couldn't keep the front wheels on the ground geared down to 3.5 mph.
I got more work down with 3x18 moving faster and the field was very level except where it was very wet because the higher speed slammed the dirt down and it crumbled and self leveled.
Gerald J.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:31pm
Consider that the 170 is essentially a D17, so absolutely maybe. On level ground, probably. On hilly clay soil, maybe not.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:42pm
Where I live d17 & 170 could pull a 4-16 real easy. We have sandy soils with hills.If you had the plow set correctly you hardly ever needed front weights.
JFREED View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JFREED Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:04pm
Is there any type of rear wheel ballast? We pulled 4/16 6-1/2 inch deep in clay soil before going to chisel plow. Does the traction booster work properly?
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:27pm
Tracy, here in the eastern hills it is my experience that 2500-3000 lbs + 25-30 hp per 16 inch bottom to pull it right. Probably a little different in your area. Scott
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:37pm
I pull 3-18 with 185, works good but wouldn't want any more without adding alot of weight.  Neighbor pulled 4-14 with 175 gas, seemed to work ok but alot of gas and alot of weight, he had a loader on it all the time.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:44pm
3- 16 will be about right'
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:59pm
We pulled 3-16 mounted on 170 diesel for years in heavy clay, but we had it set-up right for plowing. Fluid in the rears plus set of pie weights on both sides. Never an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 10:16pm
I pull 3 -18, 3 point, Ford plow with my 185. It is a load in some ground. I wonder if the AC 2000, can be changed to 16? Tracy
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 10:29pm
We pull 5-14's in sod with a D-17.
Thanks & God Bless
Dennis
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 10:38pm
Mine will handle 6-18's
ALLIS EXPRESS!
This year:
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 11:33pm
I pulled 5 18s semi mounted with a 7040 and was all she wanted. Soil type dictates plow size... always.
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 11:39pm
 Okay, D-17 can only pull a 1-14".
Thanks & God Bless
Dennis
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 7:56am
I think Eldon won.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 9:55am
From the 2000 operator's manual and 2000/3000 parts book I have it appears that its not planned to change from 18 to 16" bottoms. Seems to require drilling four new holes for each bottom in the beam top and bottom to mount the 16" bottoms at that spacing.
I know for my 4x18 it was relatively easy to take off the front bottom and move the hitch over that distance to let the second bottom become the front bottom. The hitch is very versatile.
Gerald J.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 8:39pm
I pull a semi-mount John Deere 3-16 plow with my D17 (basically the same as a 170) with no problem. I would think        3-18's shouldn't be an issue.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Dave/cvny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave/cvny Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 7:04am
When I had my farm I had a 170 diesel full front weight rack , loaded rears with weights on the back . We pulled a 2000 hyd. reset 4-16 . Never had a problem pulling it!
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 7:34am
A D17 and 170 are almost the same. A 175 is not. D17 PTO 53HP, 170 54HP, 175 60HP Gas, 175 62HP diesel
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 5:44am
Thanks Eldon you made my morning!😀😀
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 6:11pm
I pulled a 70s series 4x16 with my 175 but 4x14 or 3x16 would of been better. you should be ok with 3x18s
Edited by ctbowles 58 - 13 Apr 2017 at 6:13pm
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 7:11am
You'd think:
3 x 18 = 54
4 x 16 = 64
(64 - 54) / 54 x 100% = 18.5% increase in soil turned, you'd need 18% more horsepower.
If you had a way to measure HP while plowing, I'd guarantee the ratio of HP would be much different than that. Those 3 18's are going to be a lot closer to the 4 16's than you think.
I've pulled Deere, Oliver, Allis, and Case (old orange Case, not Case/IH) plows in my farming escapades, and I can tell you one major thing: A plow ain't a plow and soil ain't soil. Or maybe that's 2 things.
Anyway, 18 inch bottoms typically pull harder than you plan on. They want to plow a little deeper than a 16, and that's part of it. Usually the pitch and curvature of the moldboard is different within a brand of plow even between the 16 and 18, and it just takes more power, it just does in my experience.
Usually best to pull a little smaller plow faster than be at the edge of ability to handle the plow. Then when you encounter a clay knoll, alfalfa roots, a sandy hill where you have traction issues.....you can still get it done, and haul tail when the going's good and you'll do a good job.
With no prior experience in your fields, it's hard to tell you what you can do.
Edited by Tbone95 - 14 Apr 2017 at 7:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 8:50am
Likely every different AC bottom has a different shape of the moldboard and so pulls differently. For sure the support of the plow has an effect especially the side thrust and the length of the landside. Some semi mounted plows depend more on the tractor and the trailing lift wheel in the furrow for handling the side thrust so probably pull a little easier than a similar sized plow from depending on the landsides for handling the side thrust. The rear wheel rolls a lot easier than the landsides slide.
Then the deep suck share probably pulls harder than the standard suck and the width of the share should have an effect too. With anywhere from 3 to a dozen shares offered for a particular bottom it could be hard to predict how hard an AC plow could pull.
Then a rusty plow surely will pull a lot harder than a polished plow.
Some soil slides easy and some is sticky in the same field.
Gerald J.
