1949 Model D Motor Grader
TumblingIQ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TumblingIQ Quote  Post ReplyReply Direct Link To This Post Topic: 1949 Model D Motor Grader
    Posted: 10 Apr 2017 at 2:27pm
My oil filter assembly is missing the stem that goes up into the oil filter. My question is will a wd 45 oil assembly bolt right on the 201cu engine? or my other choice is: Can the stem be removed from the wd 45 oil assembly and screw right into my oil filter base. Appreciate any help I can get.
45 turboa- View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 4:42pm
WD & WD45 have the same filter base the stem pulls out of the filter base not theaded .
turbocharged
Post Options Post Options   Thanks (0) Thanks(0)   Quote TumblingIQ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 5:04pm
Thanks for the reply. Do you know if the wd or wd45 oil filter assembly will bolt right on the the model d grader with the 201cu engine?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 5:55pm
WD motor is in the early d grader.  Ergo, it will fit...
