Two piece IH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Two piece IH
    Posted: 09 Apr 2017 at 11:21am
2012 Tulare CA Farm Show, Tractor Pull with Farmall 1206 breaks in Half video shows
1st Attempt, Pull and moments later..
[TUBE]y7gKbk0jyyM[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 12:58pm
A classic example of (what appears to be) a cast iron flywheel with no scatter blanket/shield, zero tie bars to keep the chassis in one piece, and a failure of the driver to notice the injection pump had stuck a plunger near the end of the run (that's the miss-fire in the engine) which sees to it a normal shut-down of the throttle may not happen. He'd have been wise to stand on the brakes and kill the engine, but hind sight is always 20-20.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 2:05pm
The primary reason that the cast flywheel exploded is the ABUSE that the driver gave it trying to start in a faster gear than the tractor would handle.  If the RPMs are held down under 4000 and the clutch is used in the proper manner and not slipped excessively as was demonstrated at the beginning a cast flywheel can live, although it is not recommended to use a cast flywheel in high HP applications. Many of the muscle cars of the later 60s would easily run over 5000 and all of them left the factory with cast flywheels.  The NHRA became the leader in safety requiring approved steel flywheels.
