Uses for belt pulleys,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Uses for belt pulleys,,,,
    Posted: 08 Apr 2017 at 10:18pm
   My newest grandson, 15 months old,  has developed a love for riding mowers, tractors and such. I been showin him some images of tractors on the web and I happened to see a couple of pics of tractors using the belt pulleys to drive what looks like a saw mill blade,,,,
   I'd like to see members tractors hooked up to different driven equipment,,,,I imagine they was used lots way back then,,not much any more,,,,???Clap
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 9:37am
here is my '28 Allis 20-35 running a threshing machine last fall.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:30am
The front mounted and belt driven saw was used for cutting logs to firewood length. More powerful than two men on a cross cut saw, but less energy efficient than a chain saw but from a time period before affordable chain saws. Not the world's safest tool with so much saw blade exposed.
Gerald J.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:48am
If this works here is an old video of Dad and I using the home made buzz saw on the back of my C to cut up slab wood.
What is nice about this rig is that the tractors hydraulics pick it up for transport.
Is it dangerous?   YOU BETCHA!  Your only focus can be on where you are in relation to the blade on one of these things.  But a chainsaw can be just as dangerous.
Edited by Jacob (WI,ND) - 09 Apr 2017 at 10:49am
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 4:37pm
The buzz saws work great for sharpening cedar fence posts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 8:13pm
B254 cuttin a bit.
https://goo.gl/photos/wgDjR3nDKr4Dv2L5A
Edited by CTuckerNWIL - 10 Apr 2017 at 9:02am
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 9:18pm
What is the purpose of useing such a long belt? Ive seen other set ups like that.
john
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:39pm
Long belts were used to aid in alingment and to keep from having to pull tight and pull machine over!!---Long belt don't slip as much either!! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 4:02am
    I have always been very impressed with the enginuity that Americans use to make "do" when pressed with  a job to do,,,,Clap and some of the "solutions" are just amazing,,,!!! I never knew what "Buzz saw" meant,,,,and now I know,,,Clap They get the job done but dang does thet look dangerous,,,!! Whew,,,,,you dang sure wouldn't want to have to help while hungover,,and a little tipsey,,,,huh,,???
   If it was me,,,I'd have thet thing covered up like the provobial ,,,"OSHA Horse" ,,,,but it does get the job done,,don't it,,??
 The farm I grew up on had 3 JDs and one IH (I think) and always wondered what the purpose of them things goin round all the time was for,,,,Clap Don't remember ever seein them used,, tho,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 4:30am
   Hey AC,, that makes sense on the longer belts for letting the weight keepin em snug and reducing slippage,Clap.
  Mr Phil,,thet is a beautiful picture of a fall day at work,,, with winter on the way,,,,you ought to submit it for a calendar contest,,,,,Clap My caption would be,," Heavy clouds promising an early winter",,,Clap
   Hey Jacob,,,where is Kenmare from Bismark,,?? I've heard of it lots of times when headed to Belcourt,,but never knew where it was,,,,most of our "used to" trips up there were thru Black Hills, to Bismark, up to Minot, over to Rugby and north to Belcourt,,,I was always on the lookout for AC orange but never seen any,,,!! We drove right by ole Darrel's place lots of times before I knew where he lived,,,but,,next time,,I'm gonna stop in for coffee,,,,,
   I spent lots of time ridin up and down them country roads all the way to Langdon and Devil's Lake but never found anything,,course with all them trees,,,,,,,
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 7:09am
Those belt pulleys are also used to rub the tread off the toes of your boots when you're young and dumb and screwing around while raking hay.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:09am
Long belt has a flywheel effect. Saw mills used them around here. With a long belt the weight of the belt traveling between  the pulleys acts like a flywheel. this helped the engine maintain speed when the log went into the saw.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:19am
Kenmare is west of Minot so its a long ways north west of Bismark. The twist in the belt also keeps the belt running in the center of the pulley.  If you run t he belt flat it needs to be perfectly straight or the belt walks off the puleey.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:42am
d.j. those clouds were more than threatinin'!  We had to quit about an hour later as it started to rain and then snowed.  We had an early winter and there are still close to a million acres of crops still in the fields according to the farm papers.  And, Shameless must still have thet dang machine goin' , cause it's snowin here again!!Angry
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:45am
Twist in belt reverse the rotation.Dad had a buzz saw mounted on front of a W C . Open saw.Have off barid many hours next to that open saw.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 10:25am
Dad had a small corn grinder to grind hog feed mounted in a small building with a door that you would open up to run the belt out of to the tractor. Wish I had a picture of it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 10:50am
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 11:01am
The twist was done to reverse the direction of the driven pulley. We used the pulley on the WD to drive a front-mounted buzz saw, silo filler and hammer mill. We twisted the belt on the hammer mill and that was all.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 12:39pm
I remember my grandad telling me that a major reason for long drive belts was to gain distance from the dry straw to keep the risk of fire down from the steam engines that used to power the threshing machines. Obviously the long belts outlasted the steam engine.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 1:16pm
My Grandad tole me the longer the belt,, made more power, so I guess the flywheel effect has some truth to it. I also thought the long belt was to get sparking engines away from the straw pile...
The twist I know reverses rotation,,, but steam engines have power both ways, what gives here? I can better understand that perfect alignment not needed with a twist
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 1:46pm
Don't forget the belt pulleys worked hammer mills - for grinding feed, enslige cutters, for chopping and tossing silage into the silo, blowers for blowing cut up silage into silos, generators - we sold a few belt operated generators and some PTO generators, in addition to sawmills.
For information the belt pulley was standard on the WC and an option on the WD and up.
I still remember an enslige (?) cutter at a demonstration.  Nothing could pull it.  I remember I looked on the side and saw the required rpms then measured the pulley on the cutter.  I found that the pulleys mounted on the tractors were not getting the proper rpms to throw the enslige (?) - it really did not take all that power just rpms.  I put the right size pulley on a flat top WC and went up the next day and worked the machine.  Made a few sales that day.  Simple mathematics.
Good Luck!
Bill Long
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 5:51pm
way back when,
If we had a power outage (as would happen on occasion) our WC was used to run the vacuum pump for the Surge milkers.  Had to milk them darn cows every morning and night, ya know.
Dad had made a small access door on the barn, which allowed running a belt to the side pulley of the pump.
We had a "buzz" saw too.  It was mounted on the front of an F20.  Every fall, we'd cut up short pieces of scrap wood for the kitchen stove.
IIRC, it was direct, not twisted.
The F20's belt pulley was rather large and could be mounted on either side.
If you left the pulley on, get ready for some slow gear shifting.....always took a while to slow down.
I always thought it strange that tractor mfgs never designed 'synchros into their transmissions.....until much later (60's ?)  Guess it wasn't considered cost-effective.
Was it JD that first had a synchronized transmission in the 3020 ?
Edited by Gatz in NE - 10 Apr 2017 at 5:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:38pm
3010 and 4010 I think were synchro range. I know 3020 and 4020 were but had a power shift option too. I have a '68 gas 4020 SR.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:20pm
Joe...I have 2 drive on wagon hoists that are belt driven
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:35pm
Gerald J.
yeah, now that you say that....I recall a cousin had bought a 4010 with synchro
The Power Shift was first available on the 3020 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:46pm
Power shift was an new option on 3020 and 4020 that came out in 1963 simultaneously. 3020 and 4020 are different sizes, not ages. 3020 65 hp and 4020 93 or 95 hp. 4 cylinder vs 6 cylinder engines. Virtually identical hydraulics including steering by hydraulics, power brakes, and hydraulic operated differential lock. 3010 and 4020 used a poorer scheme for switching the PTO speed and splined shaft that caused more broken parts deep inside the transmission. The spline shaft bolts on and selects the speed according to a center rod in the mating flange. When the bolts work loose and it gets forced it breaks stuff inside. The 1969 model year of the 3020 and 4020 introduced a very different hydraulic system and moved the controls for the hydraulic remotes from the dash to a side console, hence they are often called "side console". There were so many differences that the two eras of 4020 don't share shop manuals or parts books, while the 4010 and 4020 do share both. Between the 4010, early 4020, and side console 4020 there are three different hydraulic remote connections and hardware.
Gerald J.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 6:22am
I think there is more belt contact area when the slack end is going away and using the long belt is more weight to better grip the pulley
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 7:47am
This was before my day, but the family used a belt on the 1936 WC to run the elevator to get ear corn and soybeans into the crib.  Used tumbling rods and a speed jack to get the power to the elevator.  Wish I had pictures, but I don't.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 8:13am
No photo but I remember a styled WC in the family that had a pulley driven loader. I think it was a clutch/cable unit. Later converted to hydraulic cylinders driven by a rear-mounted pto driven pump. It worked ok but required some skill since neither one was continuous/live operation although the WC had the drive train throw-out function.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:10am
The Amish in our area still use belt powered ensilage cutters to fill their silo(s). I have an Amish friend (he built my garage in 2011) who borrowed one of my WD-45's a couple years ago.
I took my grandkids over to watch. They had 7 teams drawing corn with 2 men on each wagon. Each team brought in 5 loads before dinner and 6 loads after, for a total of 77 loads! They completely filled the silo that day. They put almost 30 gallons of gas through the WD-45.
One of the Amish boys told me that they really liked using my tractor, because it had a lot of power. (They all seem to have old Case tractors.) They kept trying to plug the blower and cut the shear pins off in the table twice, but no plugs!
This page was generated in 0.049 seconds.
