Using a pull type scaper/pan
Tom6070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom6070 Quote  Post ReplyReply Direct Link To This Post Topic: Using a pull type scaper/pan
    Posted: 04 Apr 2017 at 9:02pm
Anybody ever used an earth pan behind a farm tractor? Looks like it would work ok, probably slow. I want to square up a few fields and improve some lanes.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 3:22am
There is some videos on youtube with people using usually big tractors and what can be done with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 4:38am
We see a lot of the tracked four wheel drive Case IH and huge Deeres here doing this, takes a lot of horsepower plus dead weight to make a pan drag and cut. Be better off behind a tracked machine.
Hyperpack View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hyperpack Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 9:58am
I have used a couple pull pans, they work very well but take a bigger tractor than you would think to be productive. A hundred horse for a 2.5 yard dolly style is good in heavy soil, a bit less if FWA. Very cheap to operate and can do very nice job with a little practice.
Hyperpack
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 12:10pm
I have and use a 2.5 yard Speed Line #600 2-wheels out back and drawbar hitch on front,---and did use it on the Oliver super 99 GM when I had the tractor! Worked good.---Later I tried to use it on a TD- 9 IH dozer,--(too slow)---Then had it on the JD 730 and worked REAL good on it. As stated, HP, more IS better on any earthmoving equipment.
Its not really slow for general work.---if diggin a lake,---- ya, way too slow for that.
I would recommend a nice 2.5- 3 yard for the average farm tractor! thanks; ac fleet
