HD16DP
R.KYLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Topic: HD16DP
    Posted: 03 Apr 2017 at 7:26pm
I JUST PURCHASED A HD16DP SERIAL# 8029. THE TAG ON ENGINE READS 16000H. THE MAN I PURCHASED IT FROM SAYS IT HAD A TURBO AND THE EXHAUST MANAFOLD LOOKS LIKE ONE FOR A TURBO. NORMS BIBLE NO TURBO ON 16000H.DID THE TURBO COME OUT BEFORE THE 16B IN THE 1970S OR HAS SOMEONE BEEN DOING SOME ADAPTING?
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 8:49pm
Can you get a picture of the engine ID plate? It will give you the catalog number (which is the spec's that it was built to) the series number (16,000 17,000 21,000 or 25000) and the engine serial number. You'll find it on the lefthand side of the engine block.
It might be a 17000 series engine. It's a lot like the 16,000 but, only with a small turbo and not like the 21,000 which had a large turbo on it.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 11:54pm
Looks like you have an operator already!
Allis Express participant
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 8:58am
manifold was probably a swap.  16's did not get turbos until B series.  16000H has different rods and piston height than the older 16000.  16000 also has slightly smaller journals on the crank so nothing will interchange with 1600H and up except sleeves and block. also will have 4 valves per cylinder unlike 16000 has 3.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 2:45pm
Yes, the operator looks like he's ready to push some dirt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 6:29pm
ACjack IHAVE THE INFO FROM THE ENGINE TAG.
ENGINE MOD 16000H
ENGINE CATALOG #4386318
ENGINE SERIAL#16-08340
THE NEW OPERATOR IS MY GRANDSON. I THINK HE LIKES THE POWER SHIFT.
THANKS EVERY ONE FOR THE INFORMATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 6:05pm
TWO MORE QUESTIONS ON TRACTOR. DO YOU CHECK TRANS FLUID WITH ENGINE RUNNING OR SHUT OFF AND DOES ANYONE KNOW WHERE I CAN GET A OPERATORS MANUAL? THANKS FOR HELP.
This page was generated in 0.219 seconds.
