Traction booster line
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: Traction booster line
    Posted: 31 Mar 2017 at 2:00am
Were do u get it? I went to local Napa they didn't have the ends never seen them before that side they said
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 6:32am
I got one a few years ago for my D-17 from AGCO. It was not cheap but had all the proper bends and fit perfect.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 8:18am
All the lines you can get at any auto parts store are low peressure lines. The traction booster line has high pressue and will m\need a high pressure line. It should have AN fittings on the end they differer from automotive and plumbing lines. AN fittings have a 45 deg flare instead of the 37 deg use on everything else. Any hydraulic shop that builds lines for heavy equipment or aircraft mechnic should have AN flaring tools. I removed The traction booster guage from My 190 and blocked it off with a aircraft plug. I put a oil pressure guage in its place.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 8:44am
What model tractor? I have good used ones for a couple models.
Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 12:52am
Its a d14
