Agco allis 9435 trans. Problem
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: Agco allis 9435 trans. Problem
    Posted: 29 Mar 2017 at 7:33pm
I have a 9435 agco allis with a semi-power shift trans. The other morning I could not get it to go into forward gear. It just grind. I always had reverse. Last nite after work I unhooked the cable (thinking that was my problem) and know I can not get it to move forward or reverse. The shuttle shift lever doesn't seem to be working right. I took that cover off the trans. Hope n for a broken fork or set screw loose but came up with nothing. I'm thinking I need 2 split it to get to the shift fork for the schuttle shift. I do have the service manual for the tractor. Anybody ever have any problem like this or advice before I split it and hope to find my problem.
Edited by ToddnwIl - 29 Mar 2017 at 7:35pm
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 11:35pm
Does that tractor have the same trans as Massey's in those years?
They have a 32 speed dynashift.
I think they had some coupler issues from the engine to the trans? Not sure though.
That would explain it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 6:20am
It's basically a massey tractor with orange paint. I have all my hydraulic functions. The four Speed power shift seems to shift like it should. But the shuttle shift and the four gears speeds don't do anything.
