185 fuel gauge
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: 185 fuel gauge
    Posted: 29 Mar 2017 at 7:11pm
Guys and gals I installed a new Agco oem fuel gauge in my new to us 185. The old gauge didn't do a thing when the key turned on. This new gauge whips all the way to the right pegged on full, but the tanks maybe half full. Should I get a new sending unit or is there something I am not doing correctly. It is grounded very well. Thanks, Dana
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 3:59am
Captain,
I'm sure others can explain this better but the sending unit is what creates the ground to the gauge. If the gauge is directly grounded to the sending unit stud it will always read full. If I remember correctly you should just have positive coming in and then the wire to the sending unit.
When you say grounded is that to the stud for the sending unit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 5:46am
Hey Gary I grounded the gauge center post to the frame. The terminal behind empty has the slide on 2wire positive connector and the post behind full has the push on single round wire connector that hooks onto the threads (like the coolant sending unit wire). Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 5:58am
I'm not around home to look but I thought mine only had two post. Are you saying yours has three?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 8:58am
Hey Gary the new $60++ gauge oem has a plastic keeper to hold it in its socket. The old gauge had a metal keeper bracket which could/would ground it. The new gauge has a threaded stud just like the other 2 poles which originates at the back of the metal body. My gauge reads full with the key on whether I ground that center post or not. I realize the circular OD of the gauge groungs in the hole, but additional ground can't hurt either. So where do yall think I should go next? Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:31am
If no one else answers by then I can look at mine when I get home. I think I have a new one on the self and can see what's on the tractor. I should be home after 3:00 if no one else answers by then. If you unhook the sending unit I believe it should read empty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:58am
Captain,
Take off the ground and see if the gauge will read empty. If it does hook up your sending unit there and see what it reads. The way I was taught was to ground the stud the sending unit goes on to test the gauge, if it feeds full the gauge works. Might just have that wire wrong. I don't think tha gauge itself needs a ground.
JayD-17(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 10:57am
I went through the same process on my 175D last year. Replaced the gauge first, then the sending unit.
A working gauge will always read Full if its good but the sending unit is faulty. A bad gauge will read nothing at all.
Have you removed the sending unit form the tank to inspect it yet? There's not much to them beyond the float, float arm and toward the top, like this little thread fine coil, which has always been the culprit in my case because that "coil" part had the wire either frayed or broke. As the float moves the arm, a little metal tab on the arms other end glides over the flat little coil strip (Which ultimately causes it to wear out over time) I believe the tab depending on where it is, changes the strength of the signal that's being sent back to the gauge, which makes the needle move on way or another, depending on the strength of the current???....I think that's how they work anyway?!!!!
Seems like you could almost fix it if you had the hands and patience of a brain surgeon!
Got my sending unit from Sandy Lake Imp.....I want to say they cost about $45, maybe?
Did this 185 come out of Ames by chance?
Edited by JayD-17(NY) - 30 Mar 2017 at 11:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 7:38pm
Thanks guys. My old gauge was dead. My new one is alive but inaccurate. I will check the sending unit next. I found this tractor 7 years ago but didnt need it so my friend in Ames bought it. So 7 years later I thought I needed it. 😆 Ames wont miss it he has 5 others. Do the sending units mount from the top of the tank? Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 7:59pm
Take good care of her.......That's the straightest most original 185 I've personally every stumbled upon:
I wonder whatever became of the front weights?
Edited by JayD-17(NY) - 30 Mar 2017 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 8:34pm
Yeah shesgetting treated like a princess already. I have all the front and rear weights. I have spent a week cleaning her, rubberizing all hydraulic lines, am/fm/ sat radio, data port, gauges, sun shade canopy, chrome stack, cream front rims and cream rear centers, silver rear rims, etc etc. Getting her in sync with the rest of the herd.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 8:47pm
Got the before picture sounds like we need an after picture soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 8:51pm
Also all new fluids,filters,thermostat and water temp sending unit. I made braces to the instrument panel and made the black ramp hinge up for quick access. Mounted fire extinguisher also. Still lots of cleaning to go. Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 8:57pm
Man, that's gonna buff out real nice......might as well start begging the Cap'n in advance, to pay a visit and take my own "after" pictures Smile....In the meantime, I think I have some more before pics of it somewhere I can share........
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:02pm
oooops, well this was it's twin, in the foreground.......
Edited by JayD-17(NY) - 30 Mar 2017 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:10pm
Jeez almost forgot the rear left final drive had leaked forever, took that off, cleaned and reinstalled with new gasket. Three of the hard to get to bolts were loose!
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:17pm
Yes, the sender is in the top of the tank. Unfortunately , it is also under the hood. No access hole provided.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:21pm
I will have to ask him the next time I see him , why he cut the muffler stack so low on all his 185's. Seems like all his door ways were plenty tall enough to get under.
Looking at my pics, it looks like the grill took a few more dings too since the first and last time I ever saw her.....even still, an easy fix - thats about the best looking grill you can ever hope to find on a 100 series AC!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:58pm
clean rake handle works for me! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 9:05am
He cut some muffler pipes off to fit in a garage at his house. I hear ya Shameless, I gots a 16 inch broken yardstick wrapped in a towel where the c, ca and wd reside!
