Seal for hydro on a 912
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Seal for hydro on a 912
    Posted: 29 Mar 2017 at 5:12pm
The seal next to the pump is leaking. The number is CR528992. Went to my bearing house and they could not find a listing.
Any suggestions on finding a new seal?
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 9:10pm
Its probably available through Simplicity under their number. When you say next to the pump, do you mean its on the axle case or is it on the Sunstrand hydro pump. At the rear when looking at the tractor or on the pump input shaft on the right side?
Edited by ACmowerguy - 29 Mar 2017 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 10:07pm
Looking at the tractor from the rear, on the left side is a shaft that runs horizontal. Two bolts hold a cast piece that is part of the pump. Just to the left of the disconnect valve. Not sure why the shaft comes out there anyway, nothing for it to run. The shaft diameter is 5/8, but the seal OD is 1.128.
Thanks for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 11:25pm
Above the filter. Is it just coming out where the shaft comes out, there's a ball bearing and a needle bearing in the little cast piece bolted on there with a oring where it's bolted to housing. If its what I think your talking about. Like ACmowerguy said you can get it from simplicity
