Oil pressure gage on B
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Topic: Oil pressure gage on B
    Posted: 28 Mar 2017 at 9:17pm
I did a stupid thing this afternoon. I tightened the gage on the filter housing and cracked the housing. If I put some Teflon tape on it will that help or do I need to replace the houing.Call me stupid
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 9:27pm
Purchase a new housing. Better in the long run. Go to a junk yard. Or maybe one of the vendors on this web site may have one.
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 10:03pm
I agree replace it I think I have one if you need it let me know.
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 8:23am
Should be easy to get a replacement one. If it is a used one use a large file to true up the mounting surface. I lay a big coarse file on the bench and move the part over it to keep it as even as possible.
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 9:44am
Belt sander works great.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 10:03am
Call up Bill Deppe or Lad Benes (Orange Knight). There are others as well.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 7:45pm
They are made from pot metal doesn't take much to crack. They also like to leak so now is the time to fix it right.
