D 17 lift problems
denney trucks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote denney trucks Quote  Post ReplyReply Direct Link To This Post Topic: D 17 lift problems
    Posted: 10 Jun 2010 at 9:36am
I have a series 4 d 17 that has been sitting in our shed for a couple of years got it out to use in Hay and the 3 point hitch lift arms will not work correctly  start the engine they go up push lever down they stay up wont go down cut off engine they will go down  I guess there is something stuck but I don't know where any help would be appreciated Thanks DD
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 10:09am
Check the TB valve spool.  It is only spring-loaded to return and sometimes can hang up.
Also, check to make sure the linkages for the 3pt lift and "bellcranks" are free and not rusted or stuck.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 10:10am
I had that experience as well as Skyhighballoon(Mike)
The problem in our case was that the draft control lever was stuck. There was a bolt at the pivot point that had seized up. A few minutes with some PB Blaster and a couple wrenches solved the problem.
