80T trailer type mower -info needed
Farmer Tom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Tom Quote  Post ReplyReply Direct Link To This Post Topic: 80T trailer type mower -info needed
    Posted: 28 Mar 2017 at 11:06am
I am working on my 80T mower and need a little info/help on a couple of items. If anyone can help, it would be appreciated.
First, the "lift cable" for this mower is no longer available from AGCO and I need to have one made. To do this, I need the size of the cable used, its overall length and any other information that will help in making a new cable for it. Or, if anyone has one available, I would be interested.
Second, the mower did not come with a "hydraulic cylinder", so I need to know what size (bore, stroke, length) that I should get to put on the mower.
Thanks in advance for any information given!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 3:47pm
Where are you located? I have a NOS lift cable, although I do not know for sure which mower it is for. I also have a few good AC hydraulic cylinders you could choose from. I'm in Maryland very near Gettysburg Pa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 10:22pm
Do you have a part number for the cable
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Tom Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 12:06am
Mikez: According to the AGCO parts book, the lift cable is part #70804360.
Edited by Farmer Tom - 29 Mar 2017 at 12:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Tom Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 12:17am
PaulB: I am in Columbus, OH (Central Ohio). I think, although I am far from being any type of expert, a lift cable was only used on the 80T mower. The next model, 82T, was a directly connected hydraulic cylinder connected to the sickle bar to the best of my knowledge. The preceding mower, a #7 trailer mower - of which I had one quite a few years back, did not use a any cable for its lift system as I remember. The lift cable part number I am looking for, according to the AGCO parts book, is #70804360. Does this number match up to your NOS cable?
Based on what I have found out, I think I have the hydraulic cylinder covered.
Thanks, Farmer Tom
Edited by Farmer Tom - 29 Mar 2017 at 12:19am
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 12:49am
The 80R (rear mounted) used a cable and I believe the 80S (front side mount) also used a cable. The old part number you would be looking for is 804360 - later replacement numbers added the 70 ahead of the original numbers. That part number just says "80" in my book, so it might be the same cable for all the 80 mowers.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 9:12am
Dads going to see if we have one in parts bin. I'm pritty sure there's a 80T mower minus the bar and gear box in our barn from when my grandfather was a dealer. I looked after I asked you for number and found parts book and it shows dif part numbers for 80T,80Sand80T
Edited by Mikez - 29 Mar 2017 at 9:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 11:47pm
Don't have it in parts bin. Would have to try to get in barn to see if there's a cable on that mower in there.
