AC715D backhoe
onion farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote onion farmer Quote  Post ReplyReply Direct Link To This Post Topic: AC715D backhoe
    Posted: 27 Mar 2017 at 5:25pm
AllisChalmers 715D backhoe need swing cylinder kit where to get parts.
thanks
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 7:57pm
Minnpar?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 9:06pm
Any good hydraulics shop. Have a 715B  Great machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 4:33pm
As the cylinders mount on plate , just remove and you should be able to find the parts at local hyd shop -
UNLESS cylinder rods are pitted or - then another problem in rebuilding .
Edited by Coke-in-MN - 30 Mar 2017 at 4:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 8:44pm
Coke, at first glance I thought the picture was of mine. Had it 30 years this year- 715 for 10 years before that and a I60 for 3 years before the 715. 43 years of A-C backhoes.
715B is retired to farm duty. 16.9 x 28 power shift duals - 8' stone fork.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 5:45pm
715B - D with a dig-more extend-a-hoe. I bought it from municipality when they traded it on a new JD machine - 2000 hours on it and was 6 years old then . Said it's service years required replacing in city budget .
 Did a lot of septic systems and frost footings for new construction with it . Replaced the timing cover on the Perkins engine where the hyd pump stresses the case if it vibrates any. Made a support going from the bell-housing to the top of pump which has done well in solving the cracking problem
