Rolling some dirt 145T
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: Rolling some dirt 145T
    Posted: 27 Mar 2017 at 2:45pm
[TUBE]http://youtu.be/RGOBL4A1APQ[/TUBE]
Edited by CAL(KS) - 27 Mar 2017 at 2:46pm
ghostriderinthesky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 9:06pm
that is a mighty fine looking grader.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 10:49pm
Be thankful that they put the steering box out in the open rather than inside the tube like a 45!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 6:17am
Nice looking machine. Was that produced between the forty-five and the M100. ...? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 7:47am
This particular machine is a '61 and if IIRC the 145's were made 60-64.  They were actually a replacement for the BD series but heavier and the 145 uses many of the same parts as a 45 including the blade circle, frame and tandems but weigh about a ton less.  The 145 uses 13x24 tires instead of 14x24.  (From Norms construction bible)  The 145 uses the 7000 engine, A direct inject 344.  The T designations is turbocharged, not all 145's were turboed.  I am pretty happy with it, a far cry from todays modern graders but it gets the job done and it paid for itself in the first 6 months.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 6:07pm
I just finished getting the steering box out of an AD4. like you said"in the tube" except it isn't power steering
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 10:46pm
There must have been a fair bit common between 45's and 145's.  I have a parts book for an AC Australia 45 and inside the front cover is the serial for a 145.  "PWD 145T/511  Eng  7000-AD-145-56"
More on serials of Allis products made outside US as mentioned on that loaded thread
The 45 book covers "Serial No 524/282 and up".  Our "Forty Five" is 524/204, which translates by "what it has and hasn't got" to somewhere in the range of 45-1347 to 45-1670.
This page was generated in 1.176 seconds.
