7000 Black Belly Blower Motor
BrianWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianWI Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Black Belly Blower Motor
    Posted: 26 Mar 2017 at 6:54pm
What is the best way to remove the cab blower motor on a 7000 Black Belly.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 7:20pm
If it's the same as the 7020 it needs to come out the top, you'll need to remove the vents inside to get at the nuts to the bolts holding the fan housing down. Just did my 7020 it is a tedious job but works better if you have another person holding the nuts underneathe while your up top
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 1:30pm
What he said, out the top and remove the vents so you can get a wrench on the nuts.  I took mine out to clean up the fan and clean out the blower compartment.  Not a bad job, just takes a little time and a couple of times climbing up and down the tractor to grab tools and put nuts and bolts down where they won't fall off.
Hurst
1979 Allis Chalmers 7000
5800 Hours
