ALLIS CHALMERS 1947 B STARTING
W3EK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote W3EK Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS CHALMERS 1947 B STARTING
    Posted: 25 Mar 2017 at 7:58pm
    Getting ready for spring started the 47' "B". Started right up but when I went to shut down with key it would no shut off. Even when removing cable from battery. Tractor has been converted to 12 v with an alternator. Switch or selanoid problem? Any help?
Thanks
W3EK@NETZERO.COM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:26pm
If it still has magneto ignition the switch is not grounding out the mag, either bad switch or broken wire. There should be a tab on the side of the mag to ground it also. The mag could also have a broken wire internally. If it has been converted to battery and coil ignition the alternator will supply voltage to keep it running if the switch is not breaking the connection.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:59pm
Sounds like the three wire alternator is back feeding the ignition circuit. It takes a lamp, resistor, or diode in that circuit to get it to stop reliably.
Gerald J.
