battery cut-off switch on 190xt
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: battery cut-off switch on 190xt
    Posted: 25 Mar 2017 at 8:25am
Just wondering if any of the 190's had battery cut-off switches or safety switches from the factory, and if so, where were they mounted?.....
Thanks,
Troy
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:01am
mine don't, but they can always be added to it
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:35am
We have them on our combines, 8050's 8070, 7020 and both 200's. On the 200 we mounted to the front cowling where the side panel "used" to be, above the clutch pedal. Split the positive cable between battery and solenoid.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 7:21pm
Leon, that's about where I was thinking about putting one on my 190.....thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 7:58pm
I'll snap a picture in the morning (if I can remember).
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:41pm
Leon, thanks!  That would be great.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 7:46pm
Here ya go Troy. I forgot that on the everything except the 7020, I put the disconnect in the ground cable from the battery, That way if the switch or cable becomes defective, it would not be live.
Leon B MO
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 9:30pm
Leon, Where did you get your switches?
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 6:08am
Leon, many thanks for the pic.!  So, you put the "original" ground cable on the switch and on the other side of the switch ran a "new" ground.  Do you have two batteries on these tractors? Did you tie both of the grounds together and run them to the switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:22am
Yes, 2 batteries, one cable from them through switch, back to housing. The switches came from some semi-truck service shop dad knows of in St. Louis. Amazon has them for about the same money. I think dad said he paid like $27 apiece.
Leon B Mo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 9:56am
We have em' in stock on our website if interested..
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 10:16am
Leon, thanks for the info.  Going to give it a try...........Best, Troy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 4:30pm
Just curious on why the negative cable?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 4:57pm
Safety. You can wrench all day on the grounded side of the battery and having your wrench accidentally touch the frame won't cause any nasty sparks. You can do the same on the hot terminal with the switch turned off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:50pm
Yep, and if the switch fails or grounds out it simply goes to ground not "hot". The battery doesn't know the difference.
Leon B MO
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 5:59am
I was always told, ground cable is always the first cable to take off and the last one to put on.
garr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garr Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 7:13am
Harbor Freight has them for less than $10
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 10:38am
Yeah, and its a get what ya pay for to!  Chinese junk. Find yourself a Cole/Hersee, Grote, or Standard Ignition unit. Put a good one on it and forgetaboutit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 11:59am
What Steve said.
This page was generated in 0.976 seconds.
