AC 170-175 weight bracket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170-175 weight bracket?
    Posted: 24 Mar 2017 at 10:21pm
When attaching a factory weight bracket on a 170-175,do you use existing bolts, or buy longer ones? Thanks Tracy
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:17am
I put a bracket and 5 weights on my 170 several years ago and used the factory bolts. I think someone said if you have 3/4 to inch thread left to tap in should be go to go. that's about what I had left and have had no issues.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:26pm
When I removed the bracket from the 175, I had to add 2 washers to keep the bolts from bottoming out. I believe the machinery handbook requires 1.5 x the bolt Dia in cast iron @ full threads= shear point of bolt (max load required to shear bolt). Hope this helps, Kevin
