190 XT Turbo
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT Turbo
    Posted: 24 Mar 2017 at 11:40am
Got the 190 XT fired up ran pretty good but looks like its going to need a turbo as its burnt thru and probably not working anyway.Are all the 190 turbos the same? This tractor is serial number 5331 think its a 1965 model if that matters.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 12:41pm
There were 2 different turbos used, Airesearch and Thompson. Either will work but use different oil lines.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 9:15pm
Earlier ones used Thompson/Rayjay turbos, but they are no longer available.  Later ones used the Airesearch turbo.  I got one from A&I for mine - you need to get the oil lines for an Airesearch unit though.
