Needing a new Home...
Hlone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Topic: Needing a new Home...
    Posted: 09 Jun 2010 at 10:34pm
I have a 1950 WD that I bought a while back with a loader on it.  A month later I found a WD45 with a plow and blade that somehow made its way over to my place.
I moved the loader from this WD to my WD45 and works nice.  I have been told by my wife that I don't need to keep two tractors around, so the WD had to find a new home to stay at.
I believe she is a good old one for use, restoration, or to add to your collection!
History:
- Tractor came out of Northern IL from a widow.
The Good:
- Everything runs and works.
- Complete solid tractor
- Hydrolics work good.  Rams and pump work fine.  Handled loader when it was attached.
- Good Tin.  Fendors have some dings and bends on the bottom edges
- Hand and Foot Clutch Solid and Tight
- Transmission & Rear End - Shifts, runs, sounds good.
- Brakes - Need TIghtening on one side, but both work
- No Oil Leaks
- NEW RIM (couple years old) on 1 side. ($350 - 400 new)
- Tire tread is good.  They are weather checked, not sure how old.
- Radiator in good shape
The Bad:
- She is a smoker!!  Tried Lucas Oil and Sea Foam, it had a slight Inprovement by using them.
- Believe the valves or guides or rings need to be replaced.
- Engine sounds and runs good.  I didn't want to tear into her and deal with what I may find.
- Exhaust Manifold has a hole in it and needs to be replaced.
- Carb will leak when you leave her sit.  I shut off the gas and that stops it.
- Not sure how well she charges or not?  Haven't gotten the generator tested 6 volt
The Ugly:
- Someone has tried (a few times) to help the appearance by using a spray can to dress her up.
- Someone welded a top link to the rear axel.  Not sure why...
I am asking $850 for her.  I am located in Central Illinois - 61770 zip
Let me know if you have questions
More Pictures:
1953 WD45
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 5:49am
Hope someone gives your WD a good home soon! Looks like a good resto/rehab project.
WC, CA, D14, WD45
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 5:58am
My wife said if i buy anything else Allis Chalmers she is LEAVING.I love my new to me tractor!  BTW she dose call me from time to time.LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 4:36pm
I believe it will be a good resto project for someone.
1953 WD45
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 4:40pm
Fred, if she calls sometimes then to me that means she is almost over it.  Don't give up too early. lol
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 9:32pm
What's wrong with his and her tractor's?
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 10:01pm
 I am sure your wife has many dresses, prs of shoes, kitchen chairs, etc. They do not understand, 1 tractor is simply not enough & besides the 45 would get lonesome.
 Fred your wife leaves everyday & always comes back! The Grandson won't let her leave you anyway...Harvey
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 10:42pm
Yep, hang in there, and eventually she'll stop calling!!!  ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 8:11am
I also have this tractor listed on Craigslist.
Some scammer from the other side of the world wants all of my information so he can send me a cashiers check and arrange shipping for the tractor.  I don't mind if a scammer really wants to buy her, but I am not going to let someone ruin my credit or open 50 credit cards in my name!
Sad state of our world...
1953 WD45
cougar766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cougar766 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 9:12am
wish I could get her  but don't the extra cash right now, so hope she finds a good home
