6000# light hot farm class
ACman75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Topic: 6000# light hot farm class
    Posted: 23 Mar 2017 at 7:58pm
What's y'alls thoughts on which Allis would be the best for this class?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2017 at 8:09pm
And what kind of RULES do you have to work with??    Gas?? diesel??? turbocharger?? RPM limits?? tire sizes?? etc, etc, etc, etc.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2017 at 8:31pm
6000lb Light Hot Farm
General Rules
1. Tractors in the class will represent models 1980 and older.
2. Limited to a box, bone-stock 3LM466 turbocharger, sealed at beginning of season, Must be the factory exhaust housing supplied with the turbo. "small" motors with small base exhaust will run with 3LM466 adapted to fit their exhaust manifold. All turbo inspections will be done by SKPP Parts for this class, 270-590-0020 or turbos can be supplied through SKPP.
3. Injection Pumps: Rotary and 10mm A pump allowed all CID combinations. P Pump allowed 399CID and below only. No electronic pumps allowed.
4. 480 CID maximum cid, 0% variance. No decubing allowed to meet spec.
5. 0-399cid, 3500rpm. 400-480cid, 3000rpm monitored by sensor (sensor part # isspro R8906). No splices in harness allowed from sensor point to plug at back of tractor. No data-loggers or computers
6. No water injection, no intercoolers or aftercoolers
7. OEM exhaust and intake manifolds only for engine series used. No recast heads No profab-style transmissions.
8. Diesel Fuel only; no pressurized power-adders (propane, nitrous, etc) of any kind allowed.
9. Front of tractor weights cannot measure beyond 13 feet of centerline of rear axle. All tractors must have front lifting device for towing
10. 18.4x38 tires maximum, any cut, radials allowed, 18.4r or metric equivalent. 460/85 R38 or 480/80 R38
11. Hitch can be no more than 20 inches in height, a minimum of 18 inches from centerline of rear axle.
12. No shifting up or down while in competition.
13. Drivers 14 years and older allowed. Any driver under 18 requires parental consent.
14. To encourage variety in class, Sheet metal/Rear end/transmission must be 1980 or older and match OEM. Engine can be in series with same OEM as Sheet metal/transmission/rear. (Examples of possible combinations: 5.9 Cummins with M5 Moline metal/UTS rear, 478 Hercules with 1800 rear/1950 sheet metal, Ford Commander sheet metal/5000 rear/Genesis engine, Allis 180 with 426, IH M rear/450 Sheetmetal/400 series engine) Numerous combinations possible!
15. No dataloggers allowed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2017 at 9:04pm
180 chassis with a 399 cubic inch 301 and a "P" pump.... hope to run 7th gear every time with 18.4 x 38 tires(maybe 8th gear).   Better turbos out there than a 3LM466.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 7:06am
Thanks Dr. I agree on the turbo. Trying to keep the playing field somewhat level for everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 7:22am
So, have you figured out what this is going to cost ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 8:07am
I would think 15k on up to whatever you wanted to spend. What kinda horsepower could be got with the rules and using the 301?
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 2:24pm
If it was me i would use a 426 cubed up to 480. Use one out of an 8070 with the ambac pump. Those are good for 500cc of fuel. Plenty for the 3lm. Would make alot of torque. Could definitely run 8th gear in a 180. I dont think the 3500rpm is enough to make up for the displacement of the big motors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 7:32pm
Well, at 6000 lbs the heavier engine isn't an asset. 7th gear at 3500 is almost the same speed as 8th at 3,000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 9:52pm
I think both are good points
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 9:56pm
Why the 180 over the 185,175?
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 11:38pm
190 with a 301 taken to 399 just so I could go with a p pump. Sounds like a fun class.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 10:21am
A 175 is out of the question. 180 or 185 is the same same when it comes to what you're asking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 10:22am
7th gear at 3500 RPM is just about 25 MPH and 8th gear at 3,000 RPM is 26 MPH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 11:46am
Yes it looks to be a fun class and not as expensive as some! It seems to be growing in Kentucky and other areas. How hard would the 190 be to get down to 6000?
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 3:44pm
According to tractor data they were 7700lbs. Remove rock housing and lighten the front end. Then pressed wheels and I think you would be close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 5:14pm
Dam right that's a fun class, 301 luvs a P pump and RPM,s for sure,,
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:26pm
Not that easy to make with a 190 rear 3-350 lbs heavier than the 180 rear and 20% slower too. We are running same rules at 7000 lbs and open rpm 399cid under .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:28pm
Don't know that the 3lm is going to hold up to 4000+ rpm ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 12:31pm
What's gonna need to be done to the 301 to hold up to 3500 rpms and p pump setup?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 4:16pm
Hardens rods, reground cam with front bolt , billet cam would be better. Stock pistons ok coated be better ,80 series injector 5 hole 16? Simple electronic water inj . And just run it !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 10:10am
No water allowed though. But okay thanks guys for all the comments. Now to find a project tractor. Would love to find a roller with some of the chassis work already done
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 3:46pm
Give Cody Adgent in Eagleville  TN a call he may have a rolling chassis 180.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 4:32pm
Larry Write on Facebook had one too, save alot of headaches going this route
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 11:07am
I've talked to Mr Larry and he's got a 190 chassis with tube front. He seems to think it would go light enough for the class
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 12:12pm
He would kno! Lots of experience there
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 11:07am
Have found a couple 190s. What mph can I expect in road gear?
This page was generated in 0.391 seconds.
