190 rear end?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Topic: 190 rear end?
    Posted: 23 Mar 2017 at 8:32am
I know the 190's and XT's had several changes to the rear ends both as updates and on going production improvements. If I understand correctly there were changes in axle size. What are the different sizes? What are the differences between an early 190 and a series III? There is XT coming up on a sale and from the pics it looks like a series III decal but I realize that may have been added. Thanks Tom
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2017 at 8:46am
Axle size early 2-3/4 vs later 3-1/4 if memory serves. Series III should have a 4 pinion differential. There are other changes at certain serial number breaks like speed changes but those are the two main changes that I know of.
Wink
I am a Russian Bot
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2017 at 4:41pm
The large axle came with the series 11. Which isn't technically a series ll. Flat top fenders and no bar grille came at the same time as the big axle. And as Long said the 4 pinion rearend came with the series lll. To look at them, you can't tell a series ll and lll apart.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2017 at 9:06pm
Actually, the larger axle started already at sn 9000, still had had bar grill and sloped fenders till sn 19000 when they got the flat top fenders and newer style grill. Series III started at sn 23000 and had 4 pinion differential.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2017 at 9:09pm
Yep, my 1967 Series I has the bigger axles.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 12:53pm
A lot of the early tractors gat the larger axle as a dealer kit.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 1:00pm
If I remember reading right, the axle size change took place sometime in 1966.
Wink
I am a Russian Bot
This page was generated in 0.067 seconds.
