Allis C Carb
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Allis C Carb
    Posted: 22 Mar 2017 at 11:17am
Can someone explain to me the difference between Zenith carbs when one model number says it's for kerosene and another one doesn't? Will the kerosene model not work well on a gas C?
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 1:28pm
Kerosene carbs will work on gas but jetting is slightly different. Leon
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 4:11pm
I have a shop manual for the C and other tractors that should explain the differences and proper tuning on line at: http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 7:57pm
A Carburetor that's set up for Kero or Gasoline will work fine. As Gerald mentioned, just a little tuning is the only difference needed. You usually don't even have to go after jets or anything like that... HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 8:48pm
Spark ignition engines running kerosene or distillate generally were started on gasoline to warm them up so the heavy fuel would vaporize and the intake manifold gathered more exhaust heat for that purpose.
Gerald J.
