  FAQ FAQ  Forum Search Search  Events Events  Register Register  Login Login
sc disc, field cult&subsoiler for wd
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: sc disc, field cult&subsoiler for wd
    Posted: 09 Jun 2010 at 7:20pm
The disc is 8', has all scrapers -1, has rear gang extentions (homemade), blades are worn but not bent or broke, I have some spare blades that go with it, all bearings OK, good little disc, $475.00
Field culitvator is pre-pin hitch WD, it bolts to the  drawbar bail and the lift arms, brackets are there, missing 2 outer tines, the piece in front of the field cultivator is a snap-coulper adapter that I made to use on a CA, it works great but it's not factory by any means, $150
The subsoiler is also pre-pin hitch WD, use your drawbar without the bail, good tooth, not bent or welded, $125
Located in east-central MO (Moscow Mills), would take $700 for 3 pieces
pm or 636-368-2363
Thanks Leon B MO
