CA Governor Shaft Loose
CA52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA52 Quote  Post ReplyReply Direct Link To This Post Topic: CA Governor Shaft Loose
    Posted: 20 Mar 2017 at 12:10pm
I was inspecting the oil lines going to the governor on my CA, and noticed the shaft coming out the top where the oil ling goes in is loose. It wiggles some and I can pull it straight up a 1/4" or so and see splines. What am I looking at to fix this?
Thanks for any help
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 3:41pm
Red locktite is one way. You want to clean the oil off both the hole and pin first. If the hole is really sloppy JB Weld will work also.
Edited by Dick L - 20 Mar 2017 at 3:43pm
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 4:07pm
x2 on JB weld.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 8:18pm
I have 3 of them on C tractors that are the same way! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 9:30pm
Pull it out and use a center punch all the way around it to make it look like a golf ball. Clean and use RED Loctite and allow to cure.
CA52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA52 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 9:17am
Sounds like a plan! Thanks for the help all!
