wd45 Hand Clutch
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: wd45 Hand Clutch
    Posted: 19 Mar 2017 at 3:49pm
Hi  Does anyone have the procedure for adjusting the hand clutch on my wd45.  Know most of how to go about it, as i hung around my father who was an ac dealer in the 50s and early 60s.  Been a very long time.  The thing I don't know is which way to move the shims.  Thanks for any help.  Just a thought, this would be a nice addition to the knowledge section.  Thanks again.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 4:19pm
To adjust clutch with clutch in tractor. Remove or add shims as required to obtain .065" clearance between clutch plates, with clutch disengaged, adjust shim packs accordingly to maintain an equal clearance all around clutch.
Effective with WD45 #165036 a three disc clutch is used.
Also mentions to always keep clutch engaged in cold weather or when tractor is not in use.
All the above info is quoted from service manual. I have not done this myself so can't tell you anymore. I'm sure others will tell you more.
jjwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjwo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 6:43pm
All I ever did was take a shim out of each and if it didn't have a tight snap yet, removed one more.
TBone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TBone Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 8:24pm
And DO NOT throw the shims away!
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 11:46pm
Thanks all for your replies.  Waiting for a little bit warmer weather to get started, but want to be as informed as possible be fore starting.  Thanks.  Will try to remember to post results when done.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 8:14pm
good idea to pack all around the clutch cavity in case you drop a shim or even a bolt.....
