Need parts for track front bogie wheel |
HD11 owner
Topic: Need parts for track front bogie wheelPosted: 18 Mar 2017 at 12:09pm |
Just noticed this and will need parts or numbers and best places to look for these items. Going to post from phone if I can. 1957 allis HD11 .Also need to know where to get get pin for connecting tracks.Edited by HD11 owner - 18 Mar 2017 at 1:15pm |
HD11 owner
Posted: 18 Mar 2017 at 12:53pm |
I'll have to repost pics from computer. These are better size of pics. I really need newer rails too.
Edited by HD11 owner - 18 Mar 2017 at 1:16pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35696 |
Posted: 18 Mar 2017 at 1:03pm |
Get the picture smaller, and let me know what you are needing. I have 7G Donor parts machine where I believe these parts interchange to HD11.
gemdozer
Posted: 18 Mar 2017 at 2:25pm |
The HD11 idler parts are't interchagable with 7g
HD11 owner
Posted: 18 Mar 2017 at 6:16pm |
I didn't think they would interchange with the 7G. Are the HD9 and the Hd11 the same on the idler and tracks except the number of links?
Might have the best luck getting the whole thing from someone. Gem Dozer do you have the parts???
Edited by HD11 owner - 18 Mar 2017 at 6:19pm |
gemdozer
Posted: 19 Mar 2017 at 5:40am |
The HD11 -HD9 use the same idler,track,roller,sprocket and am't sure if am still have some idler parts and you better removed your idler and check if you can reinstaled bearing and seal with out machined .
HD11 owner
Posted: 19 Mar 2017 at 8:59am |
I really think I am going to need the whole idler. Do you have one? I need to check with a couple of other salvage yards that are closer me. There is one in Idaho that has quite a lot of parts for these machines on line. Only know of two closer at this time and will call them the first of the week. Where can I get master pins for the tracks. Should I check with Minn Par?
gemdozer
Posted: 19 Mar 2017 at 10:57am |
Yes am still have a complet idler for HD11 but am to far from you am located near MONTREAL CANADA and am't shipping parts over 55lbs and yes you could check with MINN PAR
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Posted: 19 Mar 2017 at 11:30am |
Check with Thill Track and Tractor in Eu Clare WI
Chances are they can locate or have one . Get it off the machine and see if it can be rebuilt - IF the bearing area is not worn -
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34636 |
Posted: 19 Mar 2017 at 1:25pm |
Get it off the machine and check to see if it is rebuildable... like others have stated...
You might luck out and find the bearing races not chew through yet into the idler housing metal. and you can have a machine shop cut hub for new seal if it is worn there to bad... After inspecting and finding out the facts then proceed in which ever direction it takes you ... looking for new bearings and seals or looking for another idler. |
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 20 Mar 2017 at 7:44am |
zimmerman tractor Versailles MO has some salvage 9's and 11's in yard i believe. havnt been there a couple years but they can probably help you.
they are located in central MO, I see your in Illinois. hardest part will be breaking the track to swap out
Edited by CAL(KS) - 20 Mar 2017 at 7:45am |
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 20 Mar 2017 at 10:43am |
To break the track, if you don't mind getting a new master pin, get someone with an air arc to blow the master pin out. On my 5, I scratched my head and tried different ideas for days to break the track apart. Then my son's buddy came out with his air arc and had the master pin blown out in half an hour. Darrel
