Eliminating the traction booster on a 6080 |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2880 |
Topic: Eliminating the traction booster on a 6080Posted: 17 Mar 2017 at 1:57pm |
If a guy wanted to bypass or eliminate the cussed traction booster on a 6080 how would you go about it? I thought about putting hydraulic coupler on the line going to the lift cylinder and run the 3 pt lift cylinder of one of the tractor's remotes. Don't grasp why you engineer something that requires two levers for the full range of motion.
DougG
Posted: 17 Mar 2017 at 8:26pm |
If I'm understanding this right, just unhook the Traction Booster linkage the the 3 pt movement is all up to you
ctbowles 58
Joined: 12 Aug 2016 Location: CLARKSVILLE MO. Points: 129 |
Posted: 17 Mar 2017 at 9:07pm |
push the leaver down on the floor by the right side of the seat
and it should disable it. |
H Clark
Joined: 11 Jul 2010 Location: West Virginia Points: 404 |
Posted: 18 Mar 2017 at 4:02pm |
The external cylinder is just an assist cylinder. It also has a cylinder built inside.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
DrAllis
Posted: 18 Mar 2017 at 9:55pm |
Leave Traction Booster all the way back and use full range of Position control lever for hitch up and down.
