Getting HD7G and NEED a PART |
Page 12> |
AmericanHomestead
Joined: 17 Mar 2017 Location: Huntsville, AR Points: 16 |
Topic: Getting HD7G and NEED a PARTPosted: 17 Mar 2017 at 12:05pm |
A friend of mine is giving me his HD7G for cheap. He's up in his 80's and his wife is bugging him to get rid of all of his equipment and finally hang it up. SOooo. I'm buying his HD7G and it needs a transmission oil pump. He stripped it about 2 years ago. He says the tractor runs fine but needs this part fixed. He says he didn't let it warm up enough before running it and that is how it happened.
I'm totally new at this and I'm new at the forum so I can learn. Here is the part I need. I emailed member "DoctorCorey" as it appears he has the same HD7G loader that I have. According to his profile, he hasn't posted on this forum since 2015. Here are the pics of what I need. Notice the stripped splines on the pump.
AmericanHomestead
Posted: 17 Mar 2017 at 12:50pm |
Corey just emailed me back and he has the exact same part! HA! awesome!
Check us out on Youtube: https://www.youtube.com/user/AnAmericanHomestead |
AmericanHomestead
Posted: 17 Mar 2017 at 5:22pm |
If anyone has any advice for a new HD7G owner, I'm all ears. I do have the original 2 volume HD7G service manual by Jensales.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 17 Mar 2017 at 8:15pm |
I am not an expert to be giving HD7G advice, but I am enough of a woman expert to advise you to get them parts off the kitchen counter before your wife sees them there! Darrel
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34617 |
Posted: 17 Mar 2017 at 8:23pm |
1I was noticing that too Darrel... unless that woman is one in a million... then American HomeStead is a doubly lucky man,,,
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
orangeman
Posted: 18 Mar 2017 at 6:20am |
What is the brand of pump or pump manufacturer?
AmericanHomestead
Posted: 18 Mar 2017 at 9:04am |
:) pictures taken when the Mrs was not looking. Removed quickly. ;)
Orange, the pump is a stock original from the 7g. Anyone have a list of checks before I load her up and bring her home? |
orangeman
Posted: 18 Mar 2017 at 9:23am |
AH - So no tag on the pump - If no tag - take the shaft and coupling to a machinist - pretty simple job to make a new one.
Orangeman
darrel in ND
Posted: 18 Mar 2017 at 9:28am |
Say there American Homestead. I thinks you better keep hanging out on here for years to come. It could be a lot of fun. I don't have any insight for you on your 7, but I bet it'll be a lot of fun. If'n you know how to put pictures on here, we'd love to see some. Thanks, Darrel
AmericanHomestead
Posted: 18 Mar 2017 at 10:12am |
Yeah, one guy on facebook told me that 12 spine shafts and couplings are like gold. And after doing some research, he's right. I can't find 12 spline ANYTHING. 9 spline, 13 spline, 14 spline yes, but not 12. The tricky part is these shafts and couplings are hardened to take extreme pressures and just milling a piece of steel won't work. It needs to be properly heated and quenched to harden the metal. I'm looking forward to putting this monster to work but I'm so worried about breaking things as old as it is and having a money pit.
Life is an adventure! |
AmericanHomestead
Posted: 18 Mar 2017 at 11:22am |
On another note,what would cause the stipping here on the pump? The former owner told me it's because he didn't let the 7G warm up 20 minutes before operation. But I have seen videos on youtube where people fire up their 7G and drive off no problem.
Could there be another issue I need to check for?
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 18 Mar 2017 at 11:35am |
I think I'd be takin a look inside the pump before I spent any money on it.
When I was still workin, we repaired all kinds of equipment like that in the shop. Shafts can be welded up and recut and if the right process is followed, it can last a long time without "heat treat and quinching." There are work hardening materials out there too, kinda tough to machine sometimes, but a good shop will tell you if they can do it right. |
gemdozer
Posted: 18 Mar 2017 at 12:05pm |
Your pump must be a CESSNA PUMP and the shaft parts number should be70628246 and you better check your inside pump before order a shaft.
orangeman
Posted: 18 Mar 2017 at 12:38pm |
Cessna pump - if looking inside the pump check for a wear plate. A spec book for the pump would provide much needed information on specs. flow capacity in GPM and pressure requirement. Might also find some specs in a AC 7G service manual.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 18 Mar 2017 at 12:57pm |
Correction on the pump, is now a EATON Cessna, I had to order the nose housing as is broken on yours and get the seal package as mine was sucking air so bad. I have a donor tractor I pulled the engine/converter assembly out of, they had welded the shaft at the converter end gear. These are my 'Good ones' still in use which I believe are 14 spline, going to take to a Detroit diesel dealer and see if can match to a blower drive as it appears similar save the pump end collar. The other option is to convert the entire mess, pump, drive gear and couplers to something else.
DMiller
Posted: 18 Mar 2017 at 12:59pm |
The reason I say convert is that Minnpar can build a order for these but will have excess cost to have made, that cost is passed on where I was quoted over three hundred for just the shaft WHEN made available.
AmericanHomestead
Posted: 18 Mar 2017 at 1:05pm |
The former owner said he took it to a few fab shops and they didn't want to mess with it. I have a different pump squared away and probably a coupler too. I just want to be sure of the cause of the stripping before I just throw it on there and assume all is well with everything else.
DMiller
Posted: 18 Mar 2017 at 1:18pm |
By all of the rust it may have not been receiving enough lube from the converter or not assembled with the correct lube. There is a vent line from that housing cover for the drive gear that sends any vented gasses and fluid to the trans/final case as I remember. Mine has the hose early units had just a vent.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 18 Mar 2017 at 3:43pm |
Hub City makes splined shafts and couplings. A bearing dealer should be able to help. I do not think they make a 12 spline. I did have them make a special coupling for me but that was years ago.
Dozer
Posted: 20 Mar 2017 at 7:52am |
Are you sure it is 12 spline. You should look for a new pump. The pump mounting should be a standard. The capacity (GPM) can be determined by the width of the gears. I think it is a gear pump but not certain.
DMiller
Posted: 20 Mar 2017 at 11:24am |
It is a gear pump, two section taking suction from both the trans sump and the left hand side strainer. Is a Eaton Cessna and according to the hydraulics shop I use very much still available. Big issue will be the shaft and the couplers. The gear that drives from the converter is splined for this shaft not adapted. Would require a lot more to get it replaced that the pump.
AmericanHomestead
Posted: 20 Mar 2017 at 1:38pm |
So my issue now is finding a shaft and coupler. I got the pump on the way from Corey (thank goodness) but now I need to find the shaft and coupler. I have the stripped ones but who do I send it to so that I can have a new one fabbed?
DMiller
Posted: 20 Mar 2017 at 3:45pm |
Find a local machine shop that does prototype(small job) work. The majority can cut splines this small and work with better harder materials. Most will have access to other companies that produce spline shafting or couplers as well.
Also as I noted above look for a major hydraulic repair shop close by. Mine is 40 miles away. If they can locate materials they will attempt to purchase or build what is needed. Need to ask, was the ear of the mount already broken or loos? If it was that will allow the pump to shift under load and do as shown. There is no tag for these pumps, the part numbers are right in front of you on the mounting flange. Eaton Cessna numbers. Edited by DMiller - 20 Mar 2017 at 3:49pm |
AmericanHomestead
Posted: 22 Mar 2017 at 8:51am |
Thanks everyone, will post updates as we get this thing running.
DMiller
Posted: 07 Apr 2017 at 7:36am |
Just as a future reference for your associated hydraulics shops, these are EATON 26507-RBM , Series S-26 hydraulic pumps. Per my supplier for hydraulic parts he SHOULD be able to get these but would be in either 9 or 13 spline, then would have to modify or convert the drive gear in the converter(small side cover) to one of these and use available shafts.
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 07 Apr 2017 at 8:14am |
Ditto! My wife would be telling me to get them out of here, they don't belong here!! Imagine that! |
michale34
Posted: 07 Apr 2017 at 12:54pm |
Yea I got caught working on a chainsaw one time on the kitchen table I had a couple of news papers under it thought it would be ok but it wasent. I bought a dish washer at a auction one time for 10 bucks to put in my shop for washing chainsaw parts worked like a charm when my wife saw it she said I better not ever catch any parts in my dishwasher. but what she don't know I have used her oven for heating chainsaw crankcases in to replace the crank bearings lol
Edited by michale34 - 07 Apr 2017 at 12:55pm |
DMiller
Posted: 07 Apr 2017 at 3:59pm |
I have cooked out welding rods in our oven!!
SHHHHH!
Edited by DMiller - 07 Apr 2017 at 4:00pm |
michale34
Posted: 07 Apr 2017 at 9:22pm |
one time my mom went to get some meat out of the deep freezer and there were 4 sleeves for a hd6 in there dad was watching wrestling and mom yell what the - - - - is this in my freezer
michale34
Posted: 07 Apr 2017 at 9:26pm |
after that he wrapped them in plastic bags in a ice chest dumped ice on them with rock salt and sit over night
Page 12> |
