185 Hard starting
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 185 Hard starting
    Posted: 14 Mar 2017 at 11:57pm
I bought a 185 last fall and used it all fall on an auger. It was pretty hard starting when it got colder even plugged in I had to use ether on it. This winter I rebuilt the engine in it because it had blowby and slobbered oil. Had the head magnafluxed and planed. The pump and injectors were supposed to have been rebuilt before I got it and it does have a diesel shops tag on the pump. It still doesn't like to start. This is my only 301 but I've never had a 426 this cold blooded. Once it starts it puffs white smoke for a long time before it comes out of it. I'm thinking about adding a intake heater and unhooking the ether. Any suggestions?
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 6:30am
I have a 185, and yes mine is hard to start cold, but I plug in the block heater and it starts right off, hardly have to let it crank.  But if you try to cold start it, either and a lot of cranking may get it started.
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 7:13am
Might want to check the block heater.  Sounds like it is still cold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 8:24am
That could be true, I had to replace mine about 5 years ago, the cord shorted out.  The Agco store still had replacement block heater when I bought mine.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 8:39am
I put a new block heater and cord on it from Agco when I bought it. I haven't plugged it in yet since I rebuilt it, but being in the 60's here lately is when I tried starting it. My 7060 started up no ether. Does the intake heater make a lot of difference? A guy told me the other day his 190xt is their best starting tractor when using it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 8:43am
Might retard the timing 2 degrees.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 8:52am
Old valves were re-ground and re-used, Yes?? So, that means the old cylinder head seats were re-ground as well?? This will lower the cranking compression a bit....grinding valves and seats on a hard starting engine can add to the problem. New valves and new seats machined to the minimum valve recession spec is best. Retarding pump timing a couple degrees will help. Lowering injector pressures from 3450 to 2900 will help too.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 9:21am
Ran into this a few years ago, guy had a 185 complained how hard starting, tried everything you did, still hard to start, white smoke etc.  The problem with that one was he had a John Deere mechanic take the pump off for rebuilding etc, he timed it like a John Deere at top dead center, once I changed the timing to where Allis Chalmers wanted it, it started like a champ .
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 10:20am
Yes I did have the old valves touched up when they checked the head. Cylinder #1 ate a compression ring, but the valve and seat didn't look too bad he said. The previous owner fed it ether as there were 5 empty cans in the cab, but I really hate using that stuff. I never thought about the timing being off since they had the pump off getting rebuilt.
BigBadAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 2:31pm
185 should start pretty easy in the cold especially when using a block heater.  I thinking the injector timing is off.
Our 180 and 185 are the easiest cold start tractors of them all.  If it under 15° we plug in.  Other than that we use the glow plugs.
Jason
Bob J Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 2:44pm
I just bought a 200 diesel last year.
It does not like cold weather. I put on
a tank heater replacement from previous
owner. I plug in heater for 20 to 30 minutes
and it starts right away. I do not like to use
ether.
This page was generated in 0.122 seconds.
