Model K offset disc harrow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Model K offset disc harrow?
    Posted: 14 Mar 2017 at 7:55pm
I have a model K offset disc harrow. It has a bracket broken-missing. It is the bracket that the transport chain hooks through. If someone has a disc and could be so kind as to make a sketch of bracket I would greatly appreciate it. The little arm that holds hyd hose is missing also. Easy to make if I had the dimensions. Thanks Tracy
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 4:43pm
How's this?
My hose bracket was destroyed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 5:12pm
Joe, that is much appreciated.What type of lift cylinder does yours use?I need to get one, and was wondering what size and travel they were. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 5:19pm
I has a factory tie rod cylinder with a stoke limiting valve. I'll try to get a photo and do some measurements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 5:42pm
It looks like a 2 1/2 x 8 cylinder
Here a couple of photos. The close up shows the stroke limiter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 7:03pm
Joe, again, I appreciate the help. Thanks Tracy
This page was generated in 0.131 seconds.
