Generator help Off color good green
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Generator help Off color good green
    Posted: 14 Mar 2017 at 1:29pm
I am trying to diagnose charging issue oliver super 77  Polarize generator charges fine shut tractor off Start again will not charge Polarize again same thing shut off restart no charge Is there something wrong with generator I tried a new regulator. Any help or comments greatly appreciated
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 1:36pm
What does the generator put out when you short the field terminal to ground?
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 7:43pm
fixed one on a 77' the other day' the points wear sticking on the regulator' i also clean the wires ends. had luck' it works
This page was generated in 0.069 seconds.
