D17 diesel valves
Trenthorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trenthorn Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel valves
    Posted: 12 Mar 2017 at 2:09pm
I'm adjusting the valves and since I had the rocker arms off I wanted to adjust them cold before I started it could someone tell what I should adjust them to.
1956 WD45, 1970 190xt Series 3, 712,716,917
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 8:11pm
 INTAKE: 0.010"          EXHAUST: 0.019"
check adjustments with engine hot.
what part of Ohio are you from?
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 10:42pm
generally add a couple thou to cold settings....certainly a good starting point and can recheck hot to see how you did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trenthorn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 6:43am
I'm from around Lancaster Ohio. And OK thank you. Would you guys know the manifold torque?
