wd vs wd45
1952ac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1952ac Quote  Post ReplyReply Direct Link To This Post Topic: wd vs wd45
    Posted: 09 Mar 2017 at 9:23pm
will a wd45 engine work on a 1952 wd tractor
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 9:52pm
Yes but.... usually people end up putting a WD engine in a '45. WD engines are more plentiful.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 3:17am
dito on that.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 10:29am
The 226 (WD45) has got to be a more plentiful engine than the 201 (WD). The 226 was in the WD45, D17, 170, 175? E gleaner. They will fit in a WD. The 226 did receive some upgrades to the oil system and compression ratio changes as they got newer. The 201 was in WC and WD that I know of.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 10:39am
They made over 178,000 WC tractors and over 146,000 WD tractors. That's a lot of 201 engines AND the D17 226 on up is not a direct bolt in like a WD45 226 is. So there are way more 201 direct bolt in engines to be had in my opinion and probably more 201 engines even if you include the D17, 170 and 175 tractors.
There were something like 90,000 WD45 tractors built and (if memory serves) about 30,000, more or less D17 tractors with 226 engines and far fewer 170 and 175 tractors with 226 engines.
Edited by Lonn - 10 Mar 2017 at 10:41am
Wink
I am a Russian Bot
This page was generated in 0.344 seconds.
