Adding Hydraulic Ports to AC 6060 |
Post Reply ![]() |
Tractor_Rookie ![]() Bronze Level ![]() Joined: 12 Feb 2017 Location: smiley Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Mar 2017 at 8:36am |
Hello all, I have an AC 6060 and I am wanting to add a loader that I have found an actual AC loader for the 6060, however I only have 2 hydraulic ports in the back of my tractor, how can I add 2 more so this loader will work correctly. Is there a 2 to 4 port conversion or do I add 2 more lines? if so how. any assistance will be great thank you.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Someone offered a hydraulic outlet multipler at one time. Sad part is I can picture the add but can't think of the brand.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21934 |
Your best solution is to buy an open-center "joystick" hydraulic valve, set-up for power beyond. Then, the loader has a valve of its own and the outlets on the tractor are available for other things.
Post Reply ![]() |
