7010 New to me
rmullican View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Topic: 7010 New to me
    Posted: 08 Mar 2017 at 3:39pm
I have purchased a 7010 PD with 8000+ hrs taking delivery next week, first 7000 series I've owned. What would be the things to watch. I will be servicing all filters and fluids (engine oil, trans, hyd, rear end, engine coolant) before putting into service.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 4:39pm
it should have a water filter; change that.   I proly would worry about fluids except engine oil till u run it 100 hours and see about any problems.    it should have 2500lbs pressure from the hydraulics.   if it doesn't, it proly just needs a shim.  should be a good tractor; most problems are minor.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 6:53pm
Congrats on buying a wonderful AC 70xx series tractor. I think they're a good reliable tractor series.
Check the engine's fresh air intake pipe before air filter for a birds nest. About every year, I'll dig several handfuls of small twigs from my 7060's intake. I remove its air dust bowl (above hood), filters, and then stuff a rag inside clean air intake while I clean out twigs. The rag keeps twigs & dirt out of pipe. Don't forget to remove rag before reinstalling filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 1:53pm
Where should the coolant conditioner be located on the tractor
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 3:48pm
On the left side of the motor towards the front of the motor but on the side. It would be smaller than the oil filters on that side.
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 7:10pm
7010 did not have water filter, only engines with intercoolers. 7020, 7050, 7060,and 7080
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 7:37pm
Seen lots of 7045 with coolant filter, have one in the shed
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 7:54pm
Owned a 7010 with PS and 20:8x38 rubber back in 1982. This was
a very good and trouble free tractor. Also enjoyed the diff lock which our 7000 did not have.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 8:36pm
I second with installing the coolant filter, my 7020 didn't have one but I was told to to prevent electrolysis. And congrats on purchasing a good tractor. I bought my 7020 over a year ago and love using it, can't find enough to do with it on my small acreage, plan on doing a full restoration on it in the next couple years.
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 2:23am
my 7010 came factory with coolant filter
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 11:43am
My 7010 would overheat until I installed the radiator foam kit.   After i installed that, it warms up quickly, but never overheats.
I also had lots of small leaks on the air conditioning system.  If you have a cab, the AC needs to work.
Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 12:51pm
Thanks for all the replies, I appreciate all the experience that the members here share. AC system needs a complete rework, radiator has partial left on the foam kit
170 W/FEL, 7010 PD, 8030 FWA PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 8:34pm
Thanks for sharing your 7010's photo. Its looks like a good straight tractor. I see its got the nice stadium lights & remote mirrors. No power-shift decal on the door, so I'm assuming its got the 20 speed power director. You're going to enjoy those power shift rear rims when making quick wheel adjustments if you hook up an in furrow AC 2000 monobeam 5-16 plow, working hay, etc... Did you get any duals with it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 8:41pm
20 speed PD and no duals, a few items need work but seems solid mechanically
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 8:52pm
That is a nice 7010! Was well looked after!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 1:14am
if you need new ac hoses, it cheaper to get them thru A&I, that's where I got all mine and saved about $300. than if I had bought them thru agco. the part numbers are the same as agco's numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 7:09am
And I just ordered new 18.4R38 Michelin Agribib radials from www.petestirestore.com for mine.
Less than 2500 delivered for both.
Looks like you may need some soon.
Roscoe.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 7:14am
That's a lot of shekels if the tractor isn't going to be working hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 7:25am
Walked by it this morning and 1 rear was flat and the other was low...  Looks like tires may have moved up the list
