Shouldn't this be warranty? (AGCO red)
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Shouldn't this be warranty? (AGCO red)
    Posted: 04 Mar 2017 at 8:59am
I really think my Massey dealer should help stand behind this! After only 45 years the original tires on my Dad's 135 have rotted! They won't hold air long enough to even be able to use it for 5-10 minutes. So this week she's getting 4 brand new tires and tubes, and her first brake job. I grew up on this tractor, my Dad bought it new in 1972, paid extra to have it delivered Mothers Day morning, mom wasn't amused at all! Figured I'd be nice to the tire guy and go ahead and break the beads with the hoe before taking them up to the tire place. Hopefully he will appreciate the gesture! I hate to get rid of tires with good tread but these have more holes and cracks than the government!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 9:11am
you are a superb owner to have oem tires avoid the 'good year splits' that usually were fatal after 10 years... - tractors fared a tad better than combines as to the splits...
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 9:20am
So i gotta ask, why do these brakes look so simple to access and repair vs. the AC type (i.e. D-series, etc.)?
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 9:44am
that is easy!
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 10:01am
I was thinking the same thing Stan!! Ryan
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 12:29pm
The brakes for all the haters of the N series ford are similar Drum brake on the hub at the end of the axle. Can't tell you when they started or always were that way, Fordson? Fergeson? Maybe Creston knows?
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 3:25pm
That's a pretty good looking massey there Joe. I think they should should still look like that. To me those early 70's masseys and the 60's to 70's IH tractors are some of the best looking ever made.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 3:27pm
I can't speak for Fordson, but I kinda think they had band brakes like on a U Allis. Don't quote me on that.
The drum brakes like what are on that Massey started with the Ford 9N in 1939, and continued for a few decades in Ford, Fergie, and MF tractors. Yes, they are super easy to use, replace, and adjust. Totally unlike the Allis W and D series tractors. Not sure why Allis made them so hard to work on, but if they would've had brakes like the Fords and Masseys, they would've been nearly perfect. (If the had the factory 3pt as an option on a WD45, and the brakes like a Ford, I'd ditch the 8N!)
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 5:17pm
as long as the axle seal doesn't leak the brakes are great.  my 8n only had 1 brake that worked the other axle seal leaked.  replaced the seal. less than 2 weeks later it was leaking again.Angry  I was coming down the steep road from our upper pasture with the baler hooked to the 8n.  Hit the 1 brake that worked and the tractor shot immediately to the right jackknifing the baler and tractor....no worries, my but puckered so tight you couldn't pry me off the seat with a backhoe!!!!!  The baler was in the way in the drive way, but it wasn't going back up to the upper pasture!!!
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 7:34pm
On those 8N's if you'll take a speedy sleeve and reverse it with a bit of silicone the seal will hold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 9:24pm
If the AC brakes didn't last so long, that pin would not stick.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 10:28pm
That is very true. If they leak, the shoes get soaked and they will just slide.
My seals leaked, and I replaced them in 2014, and they haven't leaked since, and I've had "stop on a dime" brakes. The Ford guru I talked to said just be sure to put a thin coat of permatex on most everything, and you'll be good. 8Ns made in 1950, 51, and 52 had 2 axle seals, and as a result, you have to pack the rear wheel bearings. On the 48 and 49 8Ns, the 1 rear axle seal is on the outside of the bearing, so the transmission oil oils the bearing. Pretty handy I think.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 7:33am
Based on the rust and paint fade I doubt how superb he could be.   The C that my grandfather had has original paint that looks much better.   I'm betting it's not or was not shedded religiously.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 7:48am
Could be if you can't say anything nice, don't say anything at all, not everybody has shed space.
And Joe, that is a nice straight Massy.
Wink
I am a Russian Bot
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 6:24am
What's a "Shed"???
AC7060Pd 1975
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 7:18am
Have the same brake setup on my Ferguson. Easy as cake.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 7:31am
Brakes also work much better on a faster turning shaft Like AC, John Deere, IH.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 7:34am
That's a really nice looking 135. Looks cared for. I always thought those 135's were cool looking tractors and the extra transmission gears are a great upgrade form a Ford. I grew up on a 235 and always thought the 135's had a nice classic look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 8:50am
Nanuk...ask Darrell ND what a shed is!
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 9:05pm
I was raised on a 65 Massey diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 10:12am
Joe,
Love the mobile bead breaker!  LOL!  Thumbs Up  Or, should I say mobile back saver!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 7:31pm
Steve, it ended up being both, looped a cable through the rim, used the hoe to swing them off the studs and lay them down. Then broke the beads and swung them up on the trailer with it. Reinstalled them the same way. First time I ever did rear tires and my back didn't hurt!
Ford 345C TLB
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:07pm
The MF135 Orchard model has inboard disk brakes instead of outboard drums.
